yeh any air getting out the intake is bad
only if it's after the AFM. which V boy's is from the looks of it.
skylines don't cost any more than any other car to maintain. you can spend your money on rubbish mods, but most times when you spend money it gives back pleasure. think of it as a gf or a mistress.
or in your case mohsen, moisturising cream for your hand.
the boss v8s are gay.. my mate has a manual bf xr8. it doesn't really get going till 4000rpm.. then it runs out of puff and is asthmatic as shit by 5000rpm. failcar.
i suppose they are like a 'Boss' in that they make loud noises, and are generally pretty useless
i find myself lusting after big power typhoons etc.. but then i remember.. they are still a Ford Falcon
LOL i thought they were somehow american...
it's an American truck engine block.. but assembled here.
the 4.6 modular v8 is actually decent.. far more rev happy and fun to drive, although falcons never got them
the same mate's mum has a 2002 mustang convertible with this motor, much quicker than the xr8
that's really cool in a country that doesn't have bullet raodsters.
boring as shit in a country overrun with cars that sport RB25's stock and where ownership of ADR compliant V8 MX5s is a phonecall away.
but but but RB are the best enginges in the world! Race Bred bro!
wouldn't say boring just cos there are stock cars with the rb here, dropping it into an mx5 is not something you see everyday. i thought bullet cars were an american comany for some reason. havent really looked at em in a while
Guest
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
