hey guys
ive bought some manifold gasket sheet the one with the metal stuff inside, and was wondering whats the best thing to cut it with ive used sissors to sut the shape out that was fine and a drill to put the stud hole but its the centre bit thats the hard bit ive tried a hole saw, stanley knife and sissors? whats the best thing to use? i know 80% of you will say buy genuine but im not buying 6 x gaskets @45 each? anyone know if a exhuast shop makes up gaskets, im on the gold coast
oh and i forgot to add they are for td05s triangle ones i need 2 x turbo-manifold 2 x turbo-dump and 2 x dump-front
cheers
Ive used many ways but none work well. Snips, holesaws, drillbits, they all rip and tear the metal in the gasket but if you cut undersize you can usually clean it up with small snips.
Clamping it between two bits of wood or alloy, clamp to the table, then holesaw it. Works ok if your drill press is sturdy. Best way would be a proper punch set, one off purchace then you never need to buy gaskets again.
If you had a lathe you could make the punch yourself, do you know someone?
If you have a drill press, use a "gasket cutter" I assume the hole your refering to is the center.
Gasket cutter: http://www.google.com/products/catalog?hl=...IwBA#ps-sellers
Or you can make your own with a centerpunch, piece of wood and a scaple.
Or you could peen it out... ever wondered what the rounded end on a ball peen hammer was for???
Or make a jig and route it out
Or cut a hole in a piece of wood with your hole saw, then use that hole as a guide to cut it out with somthing sharp
J.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
