So much for "not mentioning it", aye?
Congrats man.... but why didn't you just save it for tomorrow's tune?
(will need details on what was replaced, results between the two etc :O)
Edited by iamhe77
Sounds like a sad excuse TJ. :)
Would have been good to meet some more Stag owners and Ive only ever met you driving on the freeway.
Edited by scotty nm35
Congratulations... a good result!
Do you have a 1/4 mile time?
Havent got it all sorted yet Bob, just waiting for the E85 tune tomorrow then I will be keen to test it. Looks like a run up to Heathcote one night as ive heard the line at Calder can be long.
I will try and make it to one of the track days too this year, especially if its at Phillip Island, ive always wanted to go there.
wow thats a very impressive result - even with the handicap.
id like to meet with some of you guys. there are lots of questions id like to ask some more experienced stag owners.
im in the SE suburbs of melb.
Sounds like a sad excuse TJ. :blink:
i'm all for a Stag meet up :down:
i need a powerFC before i'll jump on the Dyno again!, keen to see the difference it will make!
It will make a huge difference Atomaly, on the day a S2 c34 pulled 110awkw just to compare. That would jump to 170-180 im guessing, with just a tune.
wow thats a big jump.. mine pulled 160awkw at RE last time so it should jump into the 200s then i take it ?? :down:
if u see a PowerFC to fit a manual S2 C34 going cheap let me know! :blink:
Edited by atomaly
HERE you go Tom (quick search for "R34 power fc" in the For Sale section)
Edited by iamhe77
Damn, the tune didnt go ahead today, Trent cant dyno M35 Stageas as removal of the drive shafts isn't possible without taking the whole hub off.
Im booked in to RE Customs on Monday now, another wait. :P
At least its the same dyno again as the graph above, should give me some good feedback.
I hate to say I told you so Scottie....LOL
Yeh thanks Andy, right as usual. :P
Gives me time this weekend to fit the rest of the goodies I bought, Greddy map sensor, wideband logging cable and pcv catch can. (thanks Craig.)
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
