  • Replies 122
I can get 10 sets sent to me, but I can't ship them to people for that. Feel free to post the link.
IF you guys are interested in a GB, I would need a minimum order of 10 and the cost of each will be $92 shipped to your door.
So with the exchange rate Im looking at $120.08 NZD delivered?
I should mention, to get these in properly you will need to make up one (or two or three depending on how pedantic you are) basic bracket to clip it down with, cut some of the underside of the shroud, a little off the plastic on your car and maybe even trim some of the engine bay.
If you take off your battery cover shroud, you will see the difference from one side to the other.
Edited by iamhe77
I don't know how much shipping will be to NZ yet.
I have one to send off (came in an order of other stuff), so will get a shipping quote then.
Please do. I need the full amount in NZDollars. Nissan NZ is charging me an arm a leg for the battery cover. FYI parts no is 65278-AM600. 64894-AM600 not including clips or brackets.
Does that mean someone is making the brackets? :D
Nope. I'd have to have actually make something on these to warrant making up brackets.
Price quoted is from US supplier and consists of battery cover, cover shroud, shipping to me and then shipping out.
Do what Scott said or go to Bunnings and grab some metal brackets to suit :)
Edited by iamhe77
I have used www.amayama.com before, they are cheap and reliable. Shipping is not too bad either. I did a search for the part numbers you listed and the resu;ts are below in Australian dollars.
cheers
benny
Search for part 64894AM600
Maker Original Number Name Price
upon availability
(AUDEURGBPJPYUSD) Delivery period
(days) Stock Nissan 64894AM600 $ 23.42 20 Add to cart UAE
Search for part 65278AM600
upon availability
(days) Stock Nissan 65278AM600 $ 5.21 20 Add to cart UAE
Edited by bennyb110
I tryed looking for the driverside cover but only ever found the passenger side. Must have been looking in wrong place
You need the passenger side one ie the one that comes standard on a G35. Remember that the US are left hand drive.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
