Why do you want to go polycarbonate? Nissan glass is lighter than poly in most cases.
It's what all the cool people do :) Seriously I thought there was a fairly big weight saving. I wasn't too fussed about the rear screen as I know that's light as standard but door windows in particular I though was worthwhile.
I'll be either gut the standard doors or go fibreglass. Still undecided. Probably staying cheap with standard doors.
  • Replies 65
I have some coming, the 33 hardcoated kit scratch resistant. A mate ordered it along with his 32 kit. I think it's coming from that mob, there was a 6 week wait on the hard coat stuff. To be honest didn't even ask what thickness. Will post up what it's like when it arrives and I've fitted it. And I'll weigh the std door glass vs the lexan.
Anyone else bought from them?? What thickness should I go for?
I've just taken delivery of a set from them.
I went for 5mm doors and 4mm windows. Figured the extra mm won't make that much difference in weight and it may just allow me to use factory seals to put them in.
I ordered them with the oem borders too, looks cool and will be easily mistaken for glass if I can indeed us the factory seals to put them in with.
The only downside, because they really do seem to be of very good quality, is the tinting (i got them tinted grey) it is darker on the door windows than it is on the 1/4s and rear window.
Apparently it's because the door windows are thicker so they are darker as a result.
No complaints though, being formed to shape should make them easy to install and less likely to leak in the wet.
If I was to order again (which I will be for my next build) I'd buy clear and have them all tinted over here so they match, but I'm a fussy pr!ck.
The one's we have coming Jack are 5mm for the door's, other wise they won't hold there shape, and 4mm for the other.
they claim to halve the weight of the factory glass, only time will tell..
Cheers
Cheers
Did you buy yours from Plastics 4 Performance in UK ??
Thanks for the advise guys. I think clear with OEM borders is the go.
Don't think I'll bother with the hard coat as it almost doubles the price and my windows will likely be fixed so wont scratch from going up and down.
Interested in these windows for replacement rear quarter glass with naca ducts. Would be a very tight squeeze to get naca ducts happening there but need a good way of getting fresh air circulating through the car without opening windows.
Kind of a related question, I didnt want to start a new thread. Has anyone converted the power windows to a wind up handle??
Would be pretty straight forward to get going I would think if you are any good at fabrication / welding. You could use the gear off the motor to the regulator, weld the shaft / spline off another car through to the handle and hopefully where the winder motor is situated the door is flat otherwise cut and weld on something flat you can mount the hub to.
What is the reason you are thinking about it? I wouldn't think the weight saving would be that great / worth it. You would probably end up needing to use parts of the motor as a mount for your gear at the regulator end. Then you also need to do it in a way that you can take it all apart if need be down the track.
I thought there may have been a R32/R33 model which has wind up windows that could be retrofitted. The idea was that the whole assembly would be it a bit lighter and simpler with no electronics.
Yeah if you were really serious about weight reduction but needed to be able to wind windows up / down, and stripped looms / switches etc there would be a difference. But I would say if they ever did come with manual winders it would be in base model 4 door type things so the regulators might be a bit different to the coupes - opening up a world of hurt!
End of the day electric window regulators are pretty similar to manual ones, may just be a matter of finding the right winding gear from another car. Nissan may have stuck with the same basic regulator design around the era so might be possible with a visit to a nissan wrecker.
But again - if serious about weight reduction and your chosen motorsport allows it then the fixed polycarbonate windows with naca / sliders would be the way to go I would think.
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
