Hey all, just wanting to know weather i can get away with out relocating it providing i can get a belt the right size
so heres a few questions for those of you who do alot of these
Is it really nessicary to relocated the tensioner if so what are your reason?
has anyone got an idea on the length/size/number of teeth required for the belt to be used with standard location of idler and tensioner
I have always re-located it above the water pump as per the DET guide. I don't think there is a right/wrong way of doing it, as long as you can still get the correct tension on the belt, all is good.
Re-locating does make releasing/tensioning the belt a lot easier but. Saves having to remove the lower cover each time.
I have a mate who located his differently to me, and had to cut part of his lower cover away. Just don't go getting all creative like he did, serves no purpose.
Just read the rb30det guide it's all in there. Belt part number for tensioner above the water pump is Dayco 94407. 152 teeth.
Here is a link to a rb30det belt which I assume requires no re-location, I have nfi if you need to use 2x lower tensioners or not but;
http://justjap.com/store/product.php?produ...at=0&page=1
It's all too easy now for the new rb30 twin cam kids on the block lol, you even get your belt off the shelf.
Edited by James_03
fair enough, didnt think of that haha, i guess i'll have to drill it now.
It's either drill, or cut. And it looks much neater to drill.
I will soon be looking for new covers for my motor when I change to the new block.
yeah, i'll be drilling and relocating it now didnt want to as this is an ultimate budget slap together but.. i guess i gotta do it :)
just weld some extensions onto the top cover (this is what was done with mine) and you barely notice it once it is all painted up.
I'm getting ready to drill/tap mine right away here. Should a guy use the exact dimensions in the guide ie. 17.7 mm from the deck and 33 mm to the right of that small hole looking at the front of the block?
  • 4 months later...
Sorry to bring this back up guys, but I will be doing this soon and was just wondering does anyone have any tips of drilling perfectly straight (90*) to the block as I don't like the idea of the tensioner being on an angle even if very slight. Don't want the belt jumping off or anything like that, so how have you guys done it?
doesnt have to be perfect if you have the machined surface there, when you tighten up it'll pull itself square.
i used one of the gates belts off just jap and drilled exactly where the guide says to but couldnt even get the belt on, was too far out. ended up using 2 tensioners down the bottom and the belt went straight on, wtf?
thanks, I don't think I will be getting it machined as I'm on a budget and the engine shop in my town is a mega rip off, but I'd assume it's already pretty flat.
HI there
If you are getting the gates belt that is specifically designed for the rb30 conversion, then you don't need to relocate the tensioner (in fact I don't think it's long enough). In terms of the belt rubbing on the covers, I'm not sure what the issue is - I used an rb30e bottom timing belt cover and the normal rb26 top one, and it seemed fine - the belt was close but it won't rub. I also extended the bottom cover by welding on a bit of carefully folded sheet metal (this is the bit that creates a risk of rubbing IMO so as long as you do that bit carefully should be fine).
most 30 blocks are machined there from the factory
just finished bolting my covers on, used the standard 30 bottom cover and 25 top cover and it clears the belt fine
  • 1 month later...
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
