I'll have my GT-SS turbos on the car within the month, so stay tuned...
I'll hit OZ up for a dual dyno session and we'll print out a dyno sheet with dyno curves of both cars superimposed on each other so you can see the difference.
That said, they're completely different turbos.
GT-SS are small. Smaller than 2530s and rated at 280ps each. I'm hoping for 300kw @ all four from them.
GT-RS are huge. Bigger than 2540s and rated at 400ps each.
That's a 240hp difference in turbos. BIG DIFFERENCE.
I opted for maximal response for street and track use, so I went for the fastest spooling turbos I could find... Hopefully I'll be happy with them.
https://www.sau.com.au/forums/topic/31307-hks-gtss-v-gtrs/#findComment-632617
Thats my rational too will be interested to see your ressults, have you heard anything about these new trust T517Z'z, they look aweswome ! Gt SS response with 2540 power ?
https://www.sau.com.au/forums/topic/31307-hks-gtss-v-gtrs/#findComment-646263
ph1 on these forums has T517z with 8cm2 exhaust housings on his R33 GTR...
He made 347kw @ all four if I remember correctly, and when he took me for a drive, it didn't feel overly laggy (which I would have expected compared to ball bearing HKS range), but ask him for his personal experience and what rpm they make 1 bar at...
As mentioned in other threads, my build has been postponed, pending the arrival of forged internals, so it will be another month until I can give you any results of my GT-SS turbos :rofl:
https://www.sau.com.au/forums/topic/31307-hks-gtss-v-gtrs/#findComment-646388
GT-RS are not huge and are certainly not bigger than 2540's. GT-RS runs exactly the same turbine (or compressor, I cant remember) as a 2540, but is more responsive. I've been in an S14a with a GT-RS and my God does it spool up much quicker than a T28. And no other mods were put in except for the turbo.
https://www.sau.com.au/forums/topic/31307-hks-gtss-v-gtrs/#findComment-647521
Hey looking at it on paper, if you put 2 x GT-RS on an RB26 it's meant to have the same output as a T51R KAI? Does that mean the Kai is as "responsive" as a GT-RS setup, or that the GT-RS has as much lag as a big single?
If anything, I would have thought the GT-RS would have MORE lag than a big single?
https://www.sau.com.au/forums/topic/31307-hks-gtss-v-gtrs/#findComment-647823
i guess it would depend on the big single merli ;)
IE apexi AX82 big single - more lag
HKS T51 R SPL - less lag
https://www.sau.com.au/forums/topic/31307-hks-gtss-v-gtrs/#findComment-647828
Actually, I would think the standard S15 T28 spools and makes full boost quicker than the GT-RS.
https://www.sau.com.au/forums/topic/31307-hks-gtss-v-gtrs/#findComment-648558
GTSS vs GTRS, I think it would be more of what are you chasing?
and will it be on the standard displacement 2.6L?
I reckon merli is on the right track with the 2.6L + GTSS combo, matched with some cams, lightweight flywheel, should be responsive as and be fun to drive on the circuit and street.
IMO the GTRS is more suited to a 2.7+ litre combo.
But if you're after big HP then go big single?
https://www.sau.com.au/forums/topic/31307-hks-gtss-v-gtrs/#findComment-652216
MODEL Wastegate (Sold separately :*Excluding some items) Horse power*per turbine (PS) Compressor Wheel Compressor Housing Turbine Wheel Exhaust Housing
Trim In Dia. Outer Dia. In Dia. Out Dia. A/R Trim Outer Dia. Out Dia. In Flange Out Flange A/R
(mm) (mm) (mm) (mm) (mm) (mm)
GT-SS Actuator *1 280 60 46.6 60.1 *2 *2 0.6 76 53.8 47 GT25 S/V GT25 0.64
GT2540 Actuator 350 46 51.7 76.2 ¢60 ¢50 0.6 76 53.8 47 T3 S/V Only for Skylines 0.64
GT2540R Actuator 360 46 51.7 76.2 ¢70 ¢50 0.5 76 53.8 47 GT25 S/V GT25 0.64
Actuator 370 0.86
GT-RS Actuator *1 400 52 51.2 71.1 ¢60 ¢50 0.6 76 53.8 47 GT25 S/V GT25 0.64
https://www.sau.com.au/forums/topic/31307-hks-gtss-v-gtrs/#findComment-652428
The GT-RS are definnaly bigger than the 2540s, they run the larger GT2835 Compressor wheel (52 trim) compared to the GT2540 (46 trim) but both have the same exhaust size & housings.
GT-RS has 400PS output whereas the GT2540 has 350PS
https://www.sau.com.au/forums/topic/31307-hks-gtss-v-gtrs/#findComment-652455
Hi guys, I posted this a while ago, but for those that haven't read it....
Here is the data on the HKS turbos
.....................Compressor......................Turbine
....................Trim...Inducer....Exducer...Exducer...Inducer....Trim
GT2530..........63____1.860____2.344___1.883____2.098____76
GTRS.............52____1.997____2.773___1.833____2.098____76
GT2835..........52____1.997____2.773___2.020____2.204____84
GT2540..........46____2.016____2.972___1.833____2.098____76
As you can see the GTRS is merely a 2835 compressor (and cover) with a 2530/40 turbine (and cover).
Hope that helps
  • Like 1
https://www.sau.com.au/forums/topic/31307-hks-gtss-v-gtrs/#findComment-652802
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
