My engine died last night in my R34 GT-T. Basically I was driving along and suddenly I noticed it was not running on all cylinders, it was running REALLY rough. Anyway I thought (hoped) a coilpack or something had died and that I could just baby it home, but then after a couple of minutes the temp started to go up (a little - was watching on the PFC screen).
I could not pull over so I continued to baby it, but then it just started to skyrocket. I pulled straight over in a dangerous location and turned the car off. It was a really bad place to stop (basically a freeway off ramp) so i started it again as I only had to get it about another 100m's to park safetly.
It started OK and I drove it and shut off the engine as soon as I could. When I stopped the PFC read 115 degree's for water temp. I noticed a trail of water behind the car also, not sure if this was just radiator overflow or something more serious.
I left it for about an 45 minutes when help arrived. They brought water so I topped up the radiator (it had lost water, but it took less than 1 litre), then went to try and start it it, and instantly it made a horrible "siezing" kind of noise and would not turn over.
I have not inspected it further, but I am thinking it could be one of the following:
1) Blown head gasket, and maybe one of the cylinders have filled with water hence why it will now not even turn over.
2) Something wrong in the bottom end
3) Both...
Any idea's / thoughts???
Stupid cars!! Sometimes I wish I just had a normal econo shitbox like everyone else.
Edited by JustinP
https://www.sau.com.au/forums/topic/313299-diagnose-the-engine-failure/
take the spark plugs out and see if the bore/s are full of coolant.
Yep, thats my first step, I will get started on the weekend :cool:
I wonder what may have caused though. It had been running a bit hot over the past few months (not too servere though), I knew the radiator was in bad shape. Ironically a new triple core alloy radiator had arrived for it on the same day it died.
The other thing was I was only running premium 95 RON fuel in it (Perth had some servere storms and every BP I went to was either shutdown or only had limited fuel available), but I was not thrashing it too much it because of the crappy fuel, and I was watching for knock and it was not too bad either.
bugger, one of the first rules is never to put cool water into a hot car as the heat shock warps and cracks things.
I would pull spark plugs and try crank it over, if water gushes out of plug holes pull the head and go from there.
Will do.
It was hot water I put into it, luckily my dad was able to assist and bring it to me :cool:
Do you still have the cam belt and so-on attached?
Sounds like an idler bearing has let go and belt has failed.
I would assume so, I did change the timing belt and both pulleys a few months ago..... It has been slightly noisy ever since though..... wonder if that had anything to do with it.
Would that explain the running on less than 6 cylinders, over heating and the leaking of water?
Thanks for everyones input by the way. I guess I really just need to roll up my sleaves and get out in the garage and start pulling it to bits.
sounds like head gasket, does the oil look like a caramel milkshake too?
make sure if you replace the head gasket you get the head skimmed flat. Machine shop should be able to do it for under $100
Haven't checked the oil or looked at the water properly yet, it happened late last night in a area with bugger all lighting, by the time I had finished towing it home all I wanted to do was go to sleep :cool:
I will get started on it this weekend.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
