Thanks N1 GTR. She is about 10 days away on the boat. She will be kept stock, maybe some exhaust mods, Not sure if A/C is in it or not, will have to get a loom if not but that is organised. Also the bonnet, if it isn't carbon I will get a proper V Spec one for it as well.Got lots of the documents for it
  • Replies 186
If that question is directed at me, I'm running a hks single entry,120mm I think
It wasnt but hey whatever! haha. I have a funny feeling my cooler is letting me down something major. Gotta get that ARC jobby on!
Nice!
You've definatly got one of the most desirable GTR's out there.
Feel free to put some pics up here once it lands :)
jim (tuner) told me that the shown axis on my graph is in fact torque.
i'll see what else i have at home but come to think of it, im 99% sure the other 2 graphs are KW v's AFR & KW v's PSI
sorry steve, this thread is about your car & not mine :)
If you do find a proper torque graph I'd love to compare the two, it's more the cams I'm interested in although your larger turbos and porting will make a difference :D
Also don't stress about being on topic in this thread, it's all good!
If you do find a proper torque graph I'd love to compare the two, it's more the cams I'm interested in although your larger turbos and porting will make a difference :)
That is a proper torque graph :D doesn't get any better than that.
My -10s are the same size as your hks gtrs as well steve, I didn't take the larger rear housing option, although, if I want more power I'll go with the .82 hot side
That is a proper torque graph :) doesn't get any better than that.
Ah I thought you had the .82 rears
I'll get a graph when I'm at Unigroup next with tractive effort just for argument sake to show the difference. What is the rpm scale on your graph, like I can't tell what rpm is redline
what are u running paul? sorry, bit off topic :)
At the moment im running some 76 mm aftermarket job. When we go for that drive ill show this abortion to you! The end tanks look like they were made by some kid in play time!
Steve, what core exactly do you have? I bought the 105 mm duel entry to go on mine!
I don't have an rpm scale alkthough I might be able to get 1.
Pauls gtr (twoogle) made 1200nm torque on jims dyno, now that is a monsta!
yeah but this is a street engine...you cannot compare a street 26/30 to a race 26.
i will speak to jim today about obtaining a dyno graph with nm axis & see what the difference is :down:
i spoke to crd & all their dyno graphs are performed in N (newtons), hence they cant give me a NM graph.
this is what i found on google, to convert NM to N:
5NM/5M = 1N
anyway...all dyno's read different & are only good for measuring 'gains' when using the same dyno
steve - there is only 1 solution...we need to line them up :down:
Mmm I knew the core a while ago, I really can't remember right now though, but it's single entry and not super thick like the drag greddy ones. The one you've got is the one I'd change to if the current one ever came off ;)
Yes that drive needs to happen, any idea on destination? I'd like to get some brakes on the car first though
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
