Thanks N1 GTR. She is about 10 days away on the boat. She will be kept stock, maybe some exhaust mods, Not sure if A/C is in it or not, will have to get a loom if not but that is organised. Also the bonnet, if it isn't carbon I will get a proper V Spec one for it as well.Got lots of the documents for it
  • Replies 186
If that question is directed at me, I'm running a hks single entry,120mm I think
It wasnt but hey whatever! haha. I have a funny feeling my cooler is letting me down something major. Gotta get that ARC jobby on!
Nice!
You've definatly got one of the most desirable GTR's out there.
Feel free to put some pics up here once it lands :)
jim (tuner) told me that the shown axis on my graph is in fact torque.
i'll see what else i have at home but come to think of it, im 99% sure the other 2 graphs are KW v's AFR & KW v's PSI
sorry steve, this thread is about your car & not mine :)
If you do find a proper torque graph I'd love to compare the two, it's more the cams I'm interested in although your larger turbos and porting will make a difference :D
Also don't stress about being on topic in this thread, it's all good!
If you do find a proper torque graph I'd love to compare the two, it's more the cams I'm interested in although your larger turbos and porting will make a difference :)
That is a proper torque graph :D doesn't get any better than that.
My -10s are the same size as your hks gtrs as well steve, I didn't take the larger rear housing option, although, if I want more power I'll go with the .82 hot side
That is a proper torque graph :) doesn't get any better than that.
Ah I thought you had the .82 rears
I'll get a graph when I'm at Unigroup next with tractive effort just for argument sake to show the difference. What is the rpm scale on your graph, like I can't tell what rpm is redline
what are u running paul? sorry, bit off topic :)
At the moment im running some 76 mm aftermarket job. When we go for that drive ill show this abortion to you! The end tanks look like they were made by some kid in play time!
Steve, what core exactly do you have? I bought the 105 mm duel entry to go on mine!
I don't have an rpm scale alkthough I might be able to get 1.
Pauls gtr (twoogle) made 1200nm torque on jims dyno, now that is a monsta!
yeah but this is a street engine...you cannot compare a street 26/30 to a race 26.
i will speak to jim today about obtaining a dyno graph with nm axis & see what the difference is :down:
i spoke to crd & all their dyno graphs are performed in N (newtons), hence they cant give me a NM graph.
this is what i found on google, to convert NM to N:
5NM/5M = 1N
anyway...all dyno's read different & are only good for measuring 'gains' when using the same dyno
steve - there is only 1 solution...we need to line them up :down:
Mmm I knew the core a while ago, I really can't remember right now though, but it's single entry and not super thick like the drag greddy ones. The one you've got is the one I'd change to if the current one ever came off ;)
Yes that drive needs to happen, any idea on destination? I'd like to get some brakes on the car first though
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
