  • Replies 186
Yeah more than happy to, is your gearbox stock?
yeah its bone stock - as long as i dont flat change 3rd gear it will be fine :devil: common cause of breaking the box as i was told.
just let me know if my rear left tail light flickers, sometimes this occurs under heavy acceleration ;)
only jokes mate, i wouldn't be that irresponsible to run you on the street (unless you twisted my arm hard & really insisted, then i'd have no choice)
Yeah read the thread I started in the drivetrain area about gearboxes.
It's all good w can just roll on the throttle in 1st gear and by third we will just both shift slow hahaha
Private street of course
i just realised - we cant go too far if you're running e85, unless you carry a jerry can in the boot for reserve!
Hahaha yeah that sucks
I'll put a Jerry can in the boot, or bring a support car hahahaha
Maybe not make it a huge thing down the coast, or if it is that's cool I'll go in Tonys car
Edit; Its probably as bad as mine fuel econ wise with all the power he's making
sorry to hi-jack your thread.
I picked up my car from Unigroup on Saturday, as always Yavuz is a master at his craft. He has transformed my car in the way it drives, its amazingly super smooth and runs like a dream.
Thanks again Yavuz!!!! Cheers.
great work N1, hope to see you car in the flesh one day, same with yours Marko R1
Cheers buddy!
Dont make it this weekend Marko... Double D's. They will be out in force :)
This weekend is all about the booze, and watching others at racetracks :D
Did yours go to get tuned yet?
Im having a 4" exhaust made for it, then retuned, so im out for a little while.
Once its done though, just try and stop me driving it :)
Are u using titanium for added noise :D I had titanium full system on my gsxr1000 and it made all other bikes sound soft hihi
Who is making your exhaust steve and what diameter front pipes u running?
bring your helmet brus....
Ooooh definatly will do :)
Cheers!!!
Are u using titanium for added noise :( I had titanium full system on my gsxr1000 and it made all other bikes sound soft hihi
Not sure yet actually, missed a call earlier tonight about it and its too late to call back now.
I want it to sound mental, which shouldn't be hard given the cams its got.
Im concerned as my car is so low that the front pipes will get damaged on the very ordinary Sydney roads and speed humps, so yeah undecided so far.
Front pipes i'm thinking 3" into a 4" merge, then 4" all the way to the rear.
Will be very loud, so once its on the car there will have to be some fiddling with mufflers/resonators to shut it up a tiny bit.
Oh, and something that resembles a cat converter.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
