I've never seen any nismo kit on IM...
Do I need Jesse to contact them directly?
Jesse, IM, RHD Japan (used to have it listed on their website), Nengun.
They will just contact Nismo to place the order.
There have been quite a few go through Yahoo Auctions as well.
yeh found it. i think i'de go Carbon.
lets wait and see if someone gets around to doing bonnets first. would really like to be able to put my engine cover back on mainly!
Must have been difficult to find with the link in the post and all :P
Why can't you get your engine cover on?
Don't say because of the spacer as I know the cover fits with those 19mm spacers.
I thought carbon fiber was illegal under ADR, unless it comes on the car from factory.. I probs wouldnt wanna run the risk of such a blatent defect
well cam it doesnt lol.
ive already made a mess of the "front midship" bonnet protector and all.
maybe you should try fit my cover for me :P it doesnt fit man!
Dunc - wouldnt bother be coz i'de keep the stock one and then go get it cleared...if i was to be defected.. any case dont really know if its worth it. our stock ones are pretty frickin light.
As for the vents in the front bar you will have to use R33 vents... I did them recently - be prepared to cut some serious reo though
Aaron, Yeah I have 350Z brembos on mine, the Enkei wheels have loads of room for any brake upgrade.
Edited by bbenny
The defect is just an unnecessary spend of $135 over sfa gain (going Carbon over FRP). The venting, apparently, drops engine temps by 10'C; so if you were doing any track work it might be handy
So buy one.
They are readily available.
Would you prefer CARBON or FRP?
is that a nm35 bonnet
when i go to the masa sorts website and go to the m tune for the nm35 , when the list of parts comes up with pat number price etc you cant actually click on them to see what the are grrr
WTF dude? We know its not a masasports one...Its Nismo!
are you talking about the front bar or bonnet , so you reckon thats a nismo bonnet then ?
im talking about the bonnet
if so please post a link to that bonnet on a nismo site .......
Edited by Sidius
i experienced the same frustration.
i dont know if the RHD is the same..
I was talking about the front bar.
If you were talking about the bonnet why did you quote me talking about the bar?
*facepalms* nevermind dude...
:closedeyes:
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
