Why does big boost have such a bad stigma?
Its my understanding that it's not like the "boost" is anything scary in and of itself. Its combustion pressures that blow your engine up, not "boost". Some people think that because person A is running more boost with a turbo than person B with another turbo, yet theyre making the same power on the same engine, that person A more likely to scatter their engine, which is false, no? The byproduct of high boost is more air, and thus fuel, in the engine, plain and simple. Am I wrong with this logic?
You are correct in a sense. But the more you compress air the hotter it gets so leaves less room for error in the event of a slight lean out etc
It also comes from the dark ages of horribly inefficient turbos the just blew hot air at anymore than a hand full of boost.
I always think back to the millions of dollars car manufacturers put into things. Etc why doesn't ford use a tiny little turbo and 40psi instead of a gt35 to make 240 kws etc
Less boost means a more relaxed engine in general. Efficiency is key. I'm sure we would all like a lazy 7psi to make 500hp but the reality is we can so it's always a balance between response and power on our small engines
If the only thing that was different was boost you'd be perfectly correct, the issue is the higher the boost pressure the hotter the intake gas, also the higher the EGTs and hence everything is just generally hotter. Heat is the enemy as it makes detonation easier, so you need to do fancy stuff like very efficient intercoolers, water/meth injection, exotic fuels like alcohol to be able to run this kind of boost whilst still running some margin of error from detonation.
When running this close to the limit you would want to start trimming individual cylinders by using individual EGT probes etc, it starts to get expensive very fast. I doubt many (if any at all) of the guys running 35psi are just simply running an intercooler and 98 octane fuel.
You are correct.
Then it would behoove one to run a cheap simple mod like an BAT (boosted air temperature) sensor in the intake.
Here is a question...where teh hell do you find a 3 5/8" V band for theses thing?
can find 3", 3 1/2", and 4" easy.......3 5/8".....
or do you simply use a 3 1/2" unit?
Powertune have them in stock to go with the precision turbo's.
  • 3 months later...
PJ....that R34 with the stock bottom end and stock cams....what was the power at the hubs? Im presuming the dyno run is showing corrected power at the fly? Im in the UK and I want to run a single on my Forged RB26 in my R32 GTR (Stock head and cams). Im going with a T3/T4 topmount manifold and was looking at the 6262.....I want 500BHP at the hubs at no more than 25PSI.......is this gonna be do-able with the 6262? Im looking for spool compariable to uprated twins but with the ability to crack 500BHp at the wheels. What do you reccomend guys??? Exact turbo specs please?
Oh.......why all the reference to 4 Cylinder Nissan engines and even worse Toyota engines??? Surely you guys must be all running 6 cylinder RB's in the main???? Just find it a little strange as in the UK where im from there isnt a lot of skyline interest in 4 cylinder mills....its all RB26/26/30 etc.......
Cheers
Andy
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
