  • Replies 150
Posted Images
is it me or does parking suck ass near the directors hotel ????not a huge fan of leaving my car out on the street near the "drunken park" dwellers who wander around looking for a quick smash and grab .lol
and so doubt I come to any events located at the hotel, no matter who gets there gear off to show off the pole skills , sorry just my 2c
you are lucky,, the parking is even worse at the ale house, I used to work on that corner...sux ass
I always knew u was a man-hoe ;D
-D
i heard around hindley business is better lol
Really, i am pretty sure the Ale House as a big car park right next door - free parking. Parked there a few times, no issues.
Shouldn't be that bad on a Wednesday night. At worst you'll have to park on Halifax st. which will help work off that Schnitty anyway :laugh:
My woman & I are keen. Been a while....
Edited by J_Red33
If there is anyone that would like a lift in and live on the way from golden grove to the city I have a few spare seats in the m35. I can be a designated driver.
I'm in Steve. Sorry, I have been meaning to respond for a while now.
Someone may have to nudge me every now 'n then to make sure I'm awake as I volunteer at the RSPCA on Wednesday's and the doggies exhaust me.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
