Hey everyone.
Last night, my car got sideswiped, bastard drove off.
Thing is, he left bits of his light assembly all over the place. I managed to put the pieces together in a rather amateur NCIS manner, and on the bottom, it shows NISSAN japan ICHIKOH 3429 L
There was also bits of a headlight protector there.
I wanted to know if anyone has a hook up with Nissan, or can tell me the model that this part came from. Our street is a pretty quiet one, and only local traffic goes through, so it might help find the arsehole who did it.
The only lucky thing is that they swerved away from my Skyline, into the Swift that the missus drives. If the line was hit, I'd be too livid to type this, and probably in a violent rage, or thoroughly drunk.
Anyone who wants to be a smartarse about owning a swift, consider this: If we didn't have that, the missus would have to drive the skyline. Her understanding of the manual gearbox seems to be limited to mule kicking the clutch, and throwing the gearshifter like a softball pitcher's fastball. It's little, auto and usually cheap to run.
We have full insurance though, but the $600 excess sucks, as we're trying to save for a wedding.
anyhow, any help would be appreciated.
thanks
https://www.sau.com.au/forums/topic/314049-help-needed-car-sideswiped/
ICHIKOH are apparently a headlight manufacturer.
http://www.ichikoh.com/index_e.html
Is "3429 L" the entire code? Search engines keeps returning "3429-L-303" if that means anything :)
You could try calling a nissan dealer parts center?
Yeah did that. Servicing couldn't help and the parts section do not answer their phone apparently. I've sent an email, and will try again later (called three times this morning, 9am, 10am, 11am.)
pretty sure its a lhs indicator off a 2000-02 nissan pulsar.. if you see one near by check it out to see if they numbers match to be 100% sure..
If it is, ask a few panel shops nearby if anyones come in lately with that kind of damage..
Good luck mate,
Johno
Okay the part numbers are a wild goose chase. I recommend doing what I've been doing for you, i.e. looking at the physical shape of the headlight and google imaging each and every Nissan model there is (car classifieds websites are good for this). So far all I've come up with is:
and
and
Good luck mate,
Johno
Looks about right to me. Some googling turned up a russian site where the part is for a nissan bluebird, which is sold here as a pulsar.
I'm going to wander the streets looking for one with a busted left headlight, and will call in to the nearby workshops.
Thanks a heap for that Johno. Much appreciated.
-Josh
Looks like the Pulsar indicator to me. Is there a pub close by to your house? Maybe go wander around in the carpark every night for a few days, see if you can find the car.
Can you find any foreign paint marks on the Swift?
No paint marks, but there are grey curls of plastic, which I assume are from the other cars bumper.
Really shits me when people do that crap and drive off.
Damn it man, that is cruel!
The NCIS stunt made me lol though... as simple as it seems I don't think many people would think of that. Good work and I hope it means that you find the #$^%&*^%#@$$%^& *ahem*
I am on and off in your area, i will get the word out so people around keep an eye out. Will do my best to find this a-hole. I also had a similar incident but was unlucky with my findings a couple of years ago. You have my eyes and ears bud! Will also contact some places i know that deal with jap specific cars that are a bit more "backyard jobs", never know what could come up. If you want PM me your mobile, i can contact you easier if i find anything.
-Andrew
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
