Don't make come over and whoop your ass!!!! I hate to be proven wrong so here: Try to spot my swirl marks in these pics then! (I promise car was filthy in every one of these shots except the one on the driveway where you can see it has been washed). REMEMBER!!!!!! Car was 2 years old in these pics, never ever detailed ever and full of scratches, dings and swirl marks. No photoshopping and tell me doesn't she look clean? SEE! SEE?! I do not lie.
Na na na na nah!
  • Replies 57
There should be a 56K WARNING on this thread.
swirls are microscopic scratches. The reason why theyshow up on dark coloured cars is because the sides of the scratches reflect light.
This is unoticable on light coloured cars because they reflect alot of the ligh themselves.
Roy is right. Having the right things can prevent swirl marks.
Have any of you tried this stuff??
autogeek_1772_16115586
I think the only way to get rid of them is if you buffed your car and used a medium cutting polish. I suppose brasso would work.
Also when you wash your car you shouldnt be rubbing in circles. You should be going the same way as the air travels over your car.
I just cut and polished my car on saturday... it took 5 hours and i didnt have time to do the wheels..
swirls are still there..
in pics my car looks awesome, no swirls. but in real life its a diff matter.
I think it depends alot on the quality of paint. My old car was mettalic black, i worked hard on it quite often, and there was no swirls. BUT then some drunk idiot crashed into me, and i had to get one side of the car resprayed. After that, one side had swirls, and the original paint didnt. so i guess the nissan factory paint isnt that swirl resistant.
Im with justin on the swirls issue, in pics usually u just cant see swirls.
I present to u two huge pics. sorry to all those 56k users :D
Both cars have LOTS of swirls. One black one red, u cant see swirls in either so :D
you bastards.
I *am* on 56k!
and Skyline_boy, in your second picture...there are no swirls.....but there *are* trees growing out of ur car :confused:
BUT....can anyone recommend a professional? You know, the sort of person I can abuse and sue if I'm not happy lol
lol that isnt my car, thats just the result of doing something properly. I dont like lexus that much.
Guide To Detailing Your Car 6.04MB
Another guide "BUFFING FOR BEGINNERS" - shows you what polishes to use, what pads to use, and how much cutting and heat they make. worth a read
Buffing for beginners
hmmm.. how much money is in this Car wash & detailing bussiness??
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
