Hey Cara, that first photo could have been a bit better with a smaller aperture, longer exposure and lower ISO, with no flash. Were they taken hand-held? If they were, using a tripod or mounting the camera somewhere stable would have helped massively! I'm not sure how long you've had your camera, but I'm slowly learning myself, so I know it's not easy to remember it all.
The other two shots are pretty good though (despite my dislike of cats)!
  • Replies 200
Hey just a quick question to the guys who are shooting a lot of car stuff. Are you guys using polarizer filters to cut reflections. I have some pretty neat locations but with some nasty reflections flying around thats all. Info on filters and shit would be appreciated. Cheers....
Not really one of those people you are asking but yeah CPLs cut lots of reflections!
You can just rotate it around and see through the viewfinder how the image changes
So the more you rotate it the more it polarizers? They the circular polarizers?
erm... a way of thinking about it is that a circular polariser has two pieces of tinted glass
the back is fixed and screwed onto the lens - the other can rotate
as you rotate it either cuts out or lets through light coming from different angles
(due to the way they are overlapping)
Do you have one? (I'm sure there would be a good article explaining it somewhere but dont have to time to find one atm)
flash wasnt used in the first pic....and tripod was used aswell still trying to get used to the new camera tho lol especially the night photography part
On your camera you will have an 'S' Mode, which is your shutter. The longer you hold the shutter open, the more light you'll let in to the pic. Try to take another night shot with the shutter speed turned up really high and then adjust it back so you get the effect you wanted :)
This photo was taken in the middle of the night, it was fairly dark. I had the shutter open for about 30seconds.
Facebook l Redbubble l Twitter l
© Copyright All rights reserved Aaron Radford 2010
Anzac Day Model Shoot
Body Builder shoot the same weekend
Love the processing in the first pic. Nicely done :)
The last shot is great. Would love to see a bigger pic of it. What lighting did you use? Looks like one light source from the top?
Edited by siddr20
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
