Hey Cara, that first photo could have been a bit better with a smaller aperture, longer exposure and lower ISO, with no flash. Were they taken hand-held? If they were, using a tripod or mounting the camera somewhere stable would have helped massively! I'm not sure how long you've had your camera, but I'm slowly learning myself, so I know it's not easy to remember it all.
The other two shots are pretty good though (despite my dislike of cats)!
  • Replies 200
Hey just a quick question to the guys who are shooting a lot of car stuff. Are you guys using polarizer filters to cut reflections. I have some pretty neat locations but with some nasty reflections flying around thats all. Info on filters and shit would be appreciated. Cheers....
Not really one of those people you are asking but yeah CPLs cut lots of reflections!
You can just rotate it around and see through the viewfinder how the image changes
So the more you rotate it the more it polarizers? They the circular polarizers?
erm... a way of thinking about it is that a circular polariser has two pieces of tinted glass
the back is fixed and screwed onto the lens - the other can rotate
as you rotate it either cuts out or lets through light coming from different angles
(due to the way they are overlapping)
Do you have one? (I'm sure there would be a good article explaining it somewhere but dont have to time to find one atm)
flash wasnt used in the first pic....and tripod was used aswell still trying to get used to the new camera tho lol especially the night photography part
On your camera you will have an 'S' Mode, which is your shutter. The longer you hold the shutter open, the more light you'll let in to the pic. Try to take another night shot with the shutter speed turned up really high and then adjust it back so you get the effect you wanted :)
This photo was taken in the middle of the night, it was fairly dark. I had the shutter open for about 30seconds.
Facebook l Redbubble l Twitter l
© Copyright All rights reserved Aaron Radford 2010
Anzac Day Model Shoot
Body Builder shoot the same weekend
Love the processing in the first pic. Nicely done :)
The last shot is great. Would love to see a bigger pic of it. What lighting did you use? Looks like one light source from the top?
Edited by siddr20
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
