Hi guys, I need a bit of help troubleshooting something. my rb20 r32 hesitates unless i give it alot of throttle till the engine temp gauge hits half way mark. It literally stops hesitating as soon as it hits EXACTLY half way mark. And also the hesitation is always till the 2200 rpm mark, it goes away if i go over 2200 rpm and goes away completely as soon as the car reaches half way on the temp gauge...
After reading around, the likely suspects are temp sensor / fuel pump / CAT sensor / TPS, i just cant figure out which ones fit the criteria described above, anyone have any ideas? What should i replace first?
Cheers
Edited by agentx
https://www.sau.com.au/forums/topic/315196-hesitation-upto-2200-rpm/
um, the ECU when its running on cold maps has basic timing and isn't very aggressive
im not sure if you can define "hesistating" but you arent meant to trash it when its cold
under 80deg water temp the ECU will run under correction and it wont be as good as when its hot (at 80deg)
if how long before it gets to half way on your guage? 2-3 minutes? 30 minutes? an hour?
mine take about 5 minute to get from cold to around 70deg ish and then its fine
when its warming up i drive it normally (anything other than flooring it)
zzz my daily does this...every morning (sss pulsar) so freaking annoying...i've had a go at plugs, o2 sensor, filter, but apparently its just an sr thing so oh well
All of my mates Rb's are a bit sketchy when 1st started...but yeah after the warmup, tis all good.....and yeah how long does it take for your car to come up to temp?
thanks for all these responses guys! to answer a few questions, the car was performing perfectly till about a few months back (no major work done before this started happening). The hesitation isnt just the car underperforming due to the engine being cold (Ive worked with cars for quite some time now, this is definitely a fault). The problem takes around 10-12 minutes of driving to resolve and the gauge to come half way.
To describe the hesitation a bit further, if you constantly have the accelerator pressed with the same amount of force and the rpm keeps increasing, as soon as it hits 2200 rpm, it feels like the fuel supply has stopped and the exhaust note changes and it feels like someones let the accelerator go all of a sudden, and then if you give it some more gas ... it goes above that 2200 rpm spot and starts to accelerate again.
I mildly suspect my CAT is not in perfect condition (collapsed maybe?) Im getting that checked out in a week or so ... but i dont see how that can affect this at the same RPM and only till the car warms up?
I have changed plugs and bought brand new coil packs as well in the last 2 months. fuel filter has been changed.
fuel pump is another suspect you reckon?
Hi mate; i'll get another thermostat and test it out but the problem is the performance while cold, not really how long it takes to get to warm level ... it shouldn't just be cold start ... i know performance is slightly decreased when the engine is cold but this is a definite fault.
cheers
cheers
The performance decrease is due to the maps the ECU is using when below 65deg, it's not due to a cold engine/poor atomisation/etc.
My point about the thermostat is that it normally gets to operating temp. very quickly if driving so you wouldn't notice it for too long at all normally. But, IF your thermostat is sticking open then it's suddenly going to take a lot longer to get to operating temp. and as such you now have a lot more time to experience the cold start running.
Could be other things like dodgy connection on water temp sensor holding it in cold start for longer..
I know that when I built my 30, I snapped the RB20/26 water temp sensor so threw the RB25 one in there.. different resistance.. ECU thought it was in cold start all the time!
  • 1 month later...
Hi bubba, I am having troubles with idle and changed my temp sensor to one from a different NIssan. I know that it is a different colour to the one I had; what colour is the 20/26 one and what colour is the 25 one?
20/26 is yellow and 25 is brown
My car used to do this. But since the powerfc and splitfires were put in it has never done it again. Revs 100% fine when cold
Personally I'd rather a more agressive cold start to remind me not to hammer the car when cold, with the 3L it drives perfectly fine under 2000rpm on cold mornings, torque ftw :)
what can i say!!! why are you driving any rb when its cold??? let it warm up to at least the first line if not halfway by the sounds of things a blown headgasket or warped head is the way your going show your animal some respect turn it over a little build up some oil pressure fire it up give it a little flutter between 1 and 2 let it settle to a nice idle 10 mins later drive it.
all rbs run like dogs when they are cold actually most engines are not designed to be thrashed send me pm when you need new engine.
cheers
lagperformance
Bubba, mine is red. I kind of remember that when I got it the guy told me it was off a 300zx though my memory is a little hazy on this.
How do I know if my car is on cold start? Using a Consult cable I can see that the car is running at about 65 degrees when warm which is about the middle of my temp guage. Is there any other way to see of the car is running at cold start.
Thanks Ben.
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
