I just had a new battery installed so i thought i would reset the ecu...
i have to say i never had a problem like flat spots or bad idle but i found that now i have more bottom end, and very suprisingly the rev limiter seems to be kicking in just past 7000, which before used to kick in around 6500!!! :D
and it not as violent as it was before the reset...actually its quite smooth...
i am wondering if anyone had similar results from an ecu reset, or anyone know why this happened....
look forward to comments.
https://www.sau.com.au/forums/topic/31590-just-reset-my-ecu/
i had similar results on my 32 as well. you basically reset the ECU so that it will relearn your driving characteristics again. i usually reset whenever i had any mods on the car such as air pod, exhaust, new oil change and even strut and sway bars. you will notice the RPM bouncing up and down a little but that's normal. run a search thru' the forums and you will probably find more comments on resetting the ECU.
https://www.sau.com.au/forums/topic/31590-just-reset-my-ecu/#findComment-637310
Resetting has smoothed out things for me a few times.
After I've reconnected the battery I let the ECU learn things differently to other people do.
I start the car and let it idle for 5-10 mintues. First off it's a little high and sometimes it hunts a little. After a while it learns the idle and is perfectly smooth.
Then I'll turn the air con on and let it idle for about 5-10 mintues, again it hunts for a while then it's perfect. Then again with the air con on AND the rear demister on etc...
Then instead of taking it out and reving the crap out of it I just drive normal.
Works a treat for me.
J
https://www.sau.com.au/forums/topic/31590-just-reset-my-ecu/#findComment-637470
interesting comments so far...
i gotto say when i did the reset about 2 weeks ago i didnt notice much difference, but today i made sure i stepped on the brake pedal about 15 times to make sure all power drained...whereas 2 weeks ago i only pressed the brake pedal about 5 times.....
https://www.sau.com.au/forums/topic/31590-just-reset-my-ecu/#findComment-637576
Don't bother pumping the brakes, just hold the pedal down for at least 30 seconds.
What it does is closes the circuit to the brake lights, the lights will then suck all the remaining power out of the car, eg. all the power out of the capasitors etc...
So once the power is sucked out of all the capasitors in the ECU it will loose it's memory.
J
https://www.sau.com.au/forums/topic/31590-just-reset-my-ecu/#findComment-637756
im a big advocate of resetting the ECU since i did it on my DR30 (FJ20ET engine)
my last car, S13, didnt seem to make huge improvements from ECU resets, mainly it did a bit wen i got full exhaust, and also wen i got big intercooler. but nothing major really.
but the DR! wen i got it it was running shit, misfiring like hell, seeming to hit the revlimiter as it tried to come on boost, hunting at idle, just running all shades of shite. then i changed the plugs (they were pretty worn out but not totally) and unplugged battery overnite and reset the ECU, and WALLAH! absolute perfection! revved rite from 0-7000rpm redline without a hiccup, didnt hesitate on gearshifts, and didnt hesitate on/off throttle.
it felt like a new car really just from ECU reset. but this is an old management system so its probably pretty shagged haha my mate said his FJ s12 did the same thing, wenever it got rough he just reset its ECU and it was perfect again!
also i accidentally overboosted mine to like 1.2bar and it made it go all retarded too so i had to reset to fix that. (0.9 is most i usualy run, or just under)
https://www.sau.com.au/forums/topic/31590-just-reset-my-ecu/#findComment-637849
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
