thats why you should split your packages if you can, i.e. wheels, coilovers
Very obvious I thought!
Bit hard though when the kit they're talking about is 85000 yen and on a conversion rate of about 77 to the dollar, it becomes $1100.00.
If the kit could be broken down in Japan and shipped in bits, it could be got without drawing attention to the customs.
D
  • 1 month later...
  • Replies 56
Posted Images
  • 1 year later...
Would so be on this if I didn't already have new whitelines.
Rose jointed ARC R30 swaybar-
http://page18.auctions.yahoo.co.jp/jp/auction/w70349245
Currently very cheap.
Jenesis R30 rear strut brace?? $3.50 start price
http://page8.auctions.yahoo.co.jp/jp/auction/h160291805
Edited by D-limo
Very good score this if ya keen enough!
I got mine new for about $180.00 landed and this is just over $200.00 landed.
Only 11+ hours to go, so be quick if your keen enough, as these don't turn up every day, but this is a four cylinder (FJ20et) set up with 9000 tacho.
D
I think I paid over $100 for mine, but plus another hundred to get the damn things sent over from Japan several years ago. They NEVER turn up locally, so I had to take the hit.
Yours also have the correct rubber mounts at the base, whereas mine were missing, and I had to pull the switches off a 280zx.
The non-electric version of those mirrors in chrome go for staggering money.
Hey guys, any idea what these are worth? I bought them 2-3 years ago and I can't find any history of what I paid.
Saw this earlier when it was sitting at about $200 and thought of you D after our discussion the other day.
Was a big $$$ item new.. Don't know if Fantasy are still producing FJ stuff?
Not exactly rare but! This might be the answer to a lot of your camber issues.
http://www.trademe.co.nz/motors/car-parts-accessories/toyota/suspension/auction-445479661.htm
Can organise a go between if needed
Cheers, D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
