hi guys, just wanting to bounce some questions off you guys, see if i can get any responses that could help my situation
ive got all the usual mods that SHOULD make mid - high 200's (rwkw) but i'm not getting there because the boost is not holding and my coilpacks are breaking down... now the coilpacks are an easy fix, but i dont know how to fix the boosting issue.
i'm looking for it to be running anything in the range of 17-19 psi... the boost quickly spikes to 17psi... but then drops immediatly to 12psi and holds there
i've had some people sugest its;
* the rubber intake shutting closed, and i need a metal intake pipe (even though ive done the rev210 mod)
* the std. bov leaking
* the wastegate actuator spring not strong enough (even though its supposed to be a 14psi actuator, and i've pulled as much preload out of it as possible)
* i need to run an electronic boost controller, because a turbotech just wont cut it
* my coilpacks are failing and breaking down at high rpm/boost levels (i have a new set of split fires on their way) and this will cause boost to drop off as engine is not getting full spark
for reference sake the turbo is a custom job from hypergear,
it's basically a 3076 squeazed into a std comp housing an aftermarket 0.63 turbine housing the breakdown of the turbo is as follows;
- standard r33 comp housing thats been machined out to accept a 76mm exducer in 52 trim, oil and water journal bearing CHRA, 0.63 rear housing with 68 trim and with 30mm internal wastegate hole, and a "high pressure" (14ish psi) actuator
does anyone have any idea other then those ideas listed above, why its not holding anything higher then 12psi?
https://www.sau.com.au/forums/topic/317106-not-holding-boost/
To rule out the bov block it and see if it helps but should not leak at that boost.
I would go full metal intake because it could stil be geting shut on the stright part where you have not added the pipe into.
for a quick fix with the coil packs get some bcpres7s if your not already running them and gap it down low until it stops missing just to test it out.
Yes it would be better to run a ebc but I have seen the boost tees hold up just fine in high power aplications so I doubt it that so check for leaks aswell. I have a hypergear turbo aswell witha 0.63 rear and it drops off from 17.5 to about 15 at redline and thats with a 14psi acutator but yeah it should not be going to 12 like in your case.
i wouldn't stuff around with intakes if you've done the rev210 mod
even at .63 rear you won't get flat boost curve... Trent and i have tried heaps of different things. Swapped out BOV's, run i don't know how many actuators, i've got arguably the best aftermarket EBC, Blitz Spec-R, rev210 mod, etc etc.
Currently have such a beefy actuator in there at the moment that it runs 18psi with the Blitz turned off.
.63's will drop about 2-3psi at redline. That's just the way it is. And you'll find similar sized turbo's from HKS etc will have very similar boost curves.
You've probably got a few psi to pick up, but i still think at the end of the day, you'll get up to around 14psi at redline and that will be normal.
Do the splitfires, see how it goes, and then sus things out a bit further.
Also, i really don't think running 14psi at redline, after peaking at 17psi is really such a bad thing if your engine isn't built :D
How's doing the work/tuning?
Yeah thats correct you wont get flat but yeah around the 14 mark is what you will get at redline trent told me the same thing the 0.63 makes it drop down and as you said its not a bad thing to be a couple of psi down at redline
Also, i really don't think running 14psi at redline, after peaking at 17psi is really such a bad thing if your engine isn't built :)
I've done all of the work, but trent has tuned it
You can still do it with internal gate by limiting the amount of exhaust pressure that you want to dispatch. Well nothing is impossible.
im not entirelty convinced by this stao, iv'e effectivly done what this device does because i have around 12mm of preload (eg shitloads) i dont think there is much extension in the rod left... any more preload (there is no thread left on the rod anyways) and it will probably wont open at all...
Just get trent to force the gate closed the do a careful run up. If its dropping immediately from 17psi then you'll have an easy cross over point, will rule out actuators etc.
If it drops regardless, it's the turbo. If it doesnt drop its something else :)
This is interesting. So you effectively have a flatline 12psi boost curve? Not taking into account the 17psi spike?
2 problems.
You have too much gate preload. Gate preload adjusts the ramp of the boost, not neccessarily the peak boost. Too much and you get a nasty spike. Not enough and it builds boost too slowly.
What is the boost controller doing exactly? Is it wound all the way in? Does it give any adjustability? Theres no reason why it wont work.
If its wound all the way in and giving the 12psi then the signal line to the controller needs to be restricted.
Its simple boost setup really.
...and dont expect a flatline 17-19psi boost curve. Its still a small rear housing.
is that always 100percent true? if it drops regardless its the turbo?
is it possuble that there is a restriction still?
Well im assuming the exhaust has been dropped just to be certain :)
If not that can be done at the same time as everything... but immediate drop is suggesting otherwise as it wouldn't just "drop" harshly
Just noticed your said the boost dropped to 12 psi "immediately"
usually boost drops slowly as back pressure increases gradually. This "immediate" drop might be a EBC related thing.
Get Stao to bring one of his manual boost controllers and test it out.
my new splitfires arrived today , tomorrow after work i'll throw them in and see if that changes things, as the top end missfire has been getting worse... im sure the missfires wont help my boost issues
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
