I was at Eastern Creek yesterday and had an issue with the car that ruined the day. I have no idea what this is but here's what happened:
Car would only rev to about 3.5 to 4k at 11psi; it is tuned for 16psi in this range. From there the car would flutter and not want to rev any more. The problem is, this only occurs under full load acceleration; with light acceleration it's happy to rev to red line.
I checked all the hoses and nothing was loose and couldn't hear any leaks.
It's an R33gts-t and does anyone have an idea what this may be because I've got nothing??
https://www.sau.com.au/forums/topic/317390-car-not-holding-boost/
I know you said you've checked all the hoses but that would still be my guess. On a track you are full load/full boost way longer than on the street, and things you might overlook can be loose.
so...check again....all clamps on the inlet....bov returns.....vacuum hoses....you need to look for splits as well as loose clamps too, tiny splits can open under boost but not be noticeable normally.
unless it sounds like a wrx of course!!
Thanks for your replies
Nah it didn't sound like a wrx. Car sounded normal and until it reached that flutter accelerated like normal.
I'll have to re-check all the hoses on it.
It's got after market coilpacks on it. I know it's an issue but how bad are these for going through coilpacks (as in after market ones)?
what spark plug gap are you running?
my car was boost surging from 16psi to 13psi on sunday on the way to eastern creek, i worked out the boost controller was playing up, after turning the boost controller off and running stock boost the boost was fine,
is your boost surging or the engine missfiring/ spitting?
what fuel pump your running?
OK I've had another look through the car the other day. I made a mistake above and the car does hold 16psi when it does this.
Checked the exhaust to see if it was a blocked cat but when the exhaust was off the car did the same thing but only when it was at half throttle.
Checked and cleaned spark plugs - all okay.
Unfortunately I didn't check the coil packs when the spark plugs were off. I will check these though. There's Splitfires on there but I don't know how long they've been on the car for.
Any ideas on what else that may be wrong with the car?
Hey.
When did you last change your fuel filter? It may be partially blocked.
Gap your plugs to 0.8mm.
Also What voltage are you running with your pump? If it hasn't been done already, you need to wire it directly to your battery with a 30amp relay in place for correct operating voltage.
If you are using the stock AFM you may also need to change it.
RB25DET AFM's are temperamental things especially when compared to Z32 or even R32 and don’t like to run too much boost through them especially on cold days/nights.
What ecu are you running?
If its stock the problem may also be a factory safe guard known as ‘rich and retard’.
If you running Splitfire’s they should be fine but if you’re concerned have them tested.
All in all it’s just a process of elimination but to me it sounds like air/fuel ratios are out which is known to occur around this rev range on RB25DET which tells me its running rich.
I hope this may help you in some way.
Cheers.
Hey.
RB25DET AFM's are temperamental things especially when compared to Z32 or even R32 and don't like to run too much boost through them especially on cold days/nights.
If its stock the problem may also be a factory safe guard known as 'rich and retard'.
If you running Splitfire's they should be fine but if you're concerned have them tested.
All in all it's just a process of elimination but to me it sounds like air/fuel ratios are out which is known to occur around this rev range on RB25DET which tells me its running rich.
Cheers.
Thanks heaps for that info. I hadn't checked the pump to see for blackages yet; regarding the voltage, I'm not sure what it runs but I'd presume it would be wired in for the appropriate voltage. Will double check though.
I probably should have put these up earlier but these are the engine mods the car has done to it:
Apexi Power FC
GCG turbo
Deatchwerks Injectors
Hybrid front mount intercooler
Z32 air flow meter
HKS boost controller
Apexi pod
Custom metal intake pipe
Splitfire coilpacks
Ganador 3” exhaust
Catco metal cat 5” body
JJR aluminium radiator
Nismo fuel pump
I don't know how long they have been on the car for. It's putting out about 260kW at the wheels
Edited by Gunnar_11
Sweet man, nice set-up.
Get a volt meter and check your pump for sure. It should be running at about 13-13.5 volts at idle if it’s been wired correctly. I forgot to mention that it might also pay to get a can of CRC MAF/AFM cleaner. This shit works wonders.
Other than that, I would change fuel filter and plugs (coppers, 0.8mm) for security and take it to a dyno to check air/fuel ratios.
still got the stock rubber in take? when they heat up they go soft an fold on them selfs stoping air flow
  • 2 months later...
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
