  • Replies 50
  • 1 month later...
for anyone after the project Mu wheel nuts I just went through my old bedroom in my parents house the other day cleaning out all my gear and whilst taking inventory discovered I have 2 sets of these brand new in there.
these ones: photo_other_racingnut.jpg
they retail for $400 a set but from memory mine were about $300 (just under $300). will check what I paid, can do them at cost for anyone who needs a set. they are M12X1.25mm so will fit pretty much any nissan on earth including R35s etc.
they are without question the best nuts out there. like marlin said on berry's R34 they have been on and off literally hundreds of times (maybe thousands now!) and still going strong. alloy ones are toast after 4 or 5 times on and off.
I'll put them up in the for sale section soon but if anyone needs them just pm me. :D
http://www.project-mu.com.au/en/products/o..._nut_racing.php
the problem with Rays and other alloy nuts is they fatigue hot cold hot cold,
the thread becomes brittle, and yeah they either break off or come un done,
now i was atthe circuit mine were loose but .........what was worse was someone else's wheel went past me when i was doing 180+
hate to know the speed of a wheel if i am doing 180
personally looking at some titanium units,
15grams each
Edited by evl38u
So anyway here's an update on the stronger set i have been using (for a few months). The cheapie sets (red ones in pic below) seemed to stretch on the first use, and thereafter they were really difficult to get off (as thread was stretched) so even after a few uses they were just rooted, the thread was chewed out. I've used the new set (bronze colour in pics below) set for longer than the red ones, yet have a look at the difference in condition below:
Some more pics
http://www.forrestfamily.com.au/duncan/GTR...ts/P1010072.jpg
http://www.forrestfamily.com.au/duncan/GTR...ts/P1010077.jpg
There was only about $20 difference is the cost for each set. The bronze ones (about $100/set) are obviously much better/stronger/harder. I'll be sticking with these, great product, decent price.
  • 4 months later...
One last update, a few months later. The thread on the $100 set (bronze ones above) still lilke new. They havent stretched at all. Amazing the value you can find. Locally made too. I might have takem them on/off at least 40 times since.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
