I shipped the V-spec over to the new buyer through TNT. Think the cost was a little less because the trailers come over full, and go back empty so they drop the price (think he paid $450 cash to send back east). One thing to be aware of is the type of transport is goes on/in. There open and closed car carriers and would suggest staying away from sending it via rail. If sending by road, a fully enclosed carrier (carton) such as those used by TNT would be the go, less dust and dirt.
Cheers
Brendan
:cheers:
TNT offers a few types of services. check http://www.tntlogistics.com/ for more infos.
One friendly reminder.....get an insurance cover and make sure the sender takes PHOTOS of the car from front to back.......Take it while it was being loaded up to TNT trucks.
You'll need it if there is some minor scratches and you know how unreasonable some poeple can be...so..back it up with some nice solic photos.
Get the best container there is if, you pay for the better services. :cheers:
was looking at an FC in Adelaide awhile back but was deterred by the hassle of shipping the car to Perth... any idea how much it costs? also, when a car is brought interstate, what needs to be done to register it here?
got to get a permit if it doesnt have a rego to drive around........and fix whatever that they need to meet WA standards.
Go to the pit and get it checked... get approval and wah la....you got yourself a WA rego..
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
