Well its your calls but from my experience doing exhausts in sections starting at the front isn't a bad idea .
I don't see any reasons other than packaging that you couldn't start out in the 3.5 to 4 inch from the turbo to the cat and progress from there .
Also other than the transition in tube size I never found any losses from being big up the front and not so much in the middle and rear sections . I think this is a good way to go because you can develop an exhaust around how much power/gas flow you need vs the sound level you can live with / get away with . In my experience all the muffling gear is in the second half or rear third of the system so this should be where if there has to be flow limitations they should be .
The exhaust gas pressure and temperature ie always highest in an exhaust directly behind the turbo so this is where easy power can be gained or lost . If you have any significant pressure (referenced against atmospheric pressure) here then the gas out of the turbo won't pass as easily as it could do if there wasn't .
Take it to the grave , exhaust temperature drops very quickly after the turbo and when it does its density decreases and all else being equal it will slow down or lose momentum so to speak .
So in my opinion make it BIG up the front and experiment with slightly smaller tubing along the way to keep the gas speed from falling too quickly .
Also being big at the front tends to increase turbo whistling and whooshing noises if that's your thing .
My opinions only , cheers A .
  • Replies 64
Who's theory is that?
I'd argue it's equally as important the whole length. No point having a great front section if the back end is junk
Some of the WRX owners are fitting smaller diameter tailpipes to their aftermarket exhausts and the dyno's they've been posting up are showing reasonably more mid-range and nominal peak hp loss.
Gas speed is higher where they are at their hottest...immediately post turbo...and cool down from there...... resulting in less flow requirements as the exhaust progresses.
Also scroll down to the part: Can a free-flow exhaust reduce efficiency?
http://www.max-boost.co.uk/max-boost/exhaust/exhaust.htm
Edited by juggernaut1
Agreed, I run 3 and 1/2 all the way and never found a restriction until I added a custom free flowing 3 inch rear muffler to try and quieten it down a tad. The resulting power loss saw it binned faster than you can blink.
I then tried a flapper valve just before the cannon and got excactly the same power loss. 3 and 1/2 all the way for me.
^ The stuff further down the page by the Garrett Engineer does tend to disagree with some of what's on the page earlier which is interesting to read (for those that might not scroll further down)
Yes his comments also disagree with the real world on the dyno findings too in relation to WRX's which is what his comments were aimed at....although I suspect he's generalising and applying that to WRX's.
I am not sure what power you are making so its hard to say. Obviously in your case 3" even at the end of the exhaust is too much of a restriction. In this case I would propose that maybe a 3.5 inch dump pipe at the front is only just flowing what you are giving it. Possibly a 4" dump would increase power and response. And yes you could leave the 3.5" cat back system as the exhaust gasses have cooled down by then.
Agreed, I believe I was at the limit of what that system could flow.
Stainless, decat.
I only ask cause I had some ghey big arse twin muffler system and I removed it for a 3" custom stainless as a quick fix ($550...)
Prev owner ceramic coated exhaust manifolds, turbine housing, dump pipes and front pipes - don't know sizing...
I'm down on power for what my setup is and am trying to figure out why atm.
Stock Cams in that car James. Could this be the issue perhaps? When you say "down on power" what are you making? Isn't it making 400+ awhp?
.............(the other possibilty is it has pink wheels.. easy losing 50hp and small dose of street-cred..) :merli:
Edited by R32 TT
Stock cams aren't such terrible things.
I managed 476hp atw on stock cams, the ecu wouldn't run more boost but it wouldve made heaps more.
Also, RacePace do everything on stock cams, do a search for "RB29" and that will show you stockers aren't that bad :/
What about running twin 2.75 inch off each turbo? Or would you still need 3 inch? That would make it interesting, I've seen the twin pipes (one off each turbo as it's own system) at Central Circuit Drags in Japan but wouldn't have a clue what size they were, I suppose that would be another avenue to go down.
For the record I run unknown front pipes into 3 inch merge then Unknown high flow cat and 3.5inch Kakimoto after that with 2 mufflers. The least amount of restriction in a turbo car the better I always thought, you don't need to worry about back pressures like you do in N/A.
On the WRX's with them running the smaller rear pipes off the mufflers, they do that in WRC too so must be a reason for it, it's not to make them quieter because they are still loud as f**k!
I believe in the World Rally Car class they reduce the latter part of the exhaust to keep the gas speed up as it cools which helps make more mid range torque .
With WRC they are limited by turbo air restrictors so they have to make as much torque as possible over a limited rev range . They're changing up at five and a bit thousand revs because the restrictors won't allow enough airflow for them to make usefull power any higher .
Between ALs and the restrictors they do make good torque but its very hard on the engines .
A .
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
