aybee:
dont listen to these guys saying they would spend 22k on a gtr instead of your car.
if u spent that little on a gtr, you would most likely be spending a lot more in the end to keep it going.
A car like yours is worth whatever someone is willing to pay for it, and by someone offering 18k, it shows that your asking price is not completely unreasonable.
  • Replies 78
aybee:
thank you.
ps. i really dont want to see the car go for 18k so im looking for 19k without rwc. (car is in rwc condition, the guy offering 18k is a mechanic and had it on a hoist)
Didn't want to start a debate or arguement because this is a for sale thread but Thumpr what I said was relevant because I was trying to help Aybee make a sale by giving him advice because he wanted offers over $18k and I was simply saying that the chances of someone offering over $18k were pretty slim. I'm not saying spending $22k on a crap/average GTR over an awesome GSTT is a smart decision, but its a decision that a lot of people make just to own and drive a GTR. Most people look and see $22k for a R32 GTST and dismiss, sad but true. Good luck with the sale though didn't want to start controversy.
Can you post updated pics ?
yeah, sorry guys my digi cam has been of action for a while.
have organised for a friend to take the pics tomorrow then email them to me, so should be up by tomorrow afternoon :D
i think people will appreciate this car more when they see the pics.
***edited price to 19k***
  • 3 months later...
drewecrome, seriously man 17500 would only buy you a clean stocker with exhaust, rims and maybe fmic. this things has the works and could pump out ~250-260rwkw. 19 grand, no rwc is the price. and i can organise freight if needed.
just to give everyone an idea of how much highly modified r32s go for and that mine is definetely not over priced.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=42463
this is why im not going to accept stupid offers in the 17s.
  • 3 weeks later...
i have spent a little bit of cash on the car so now the price is:
$19,700 Firm!
changes are:
replaced kakimoto exhaust with HKS Super Dragger
repairing and truing up the manifold
so now the exhaust from engine back is perfect.
Tried to call you but your phone was unavailable.
I'm very interested in this car, have been looking at R32's with exhaust / wheels for around $16000 with the idea of doing work to them. Your car looks VERY attractive.
Can I organise to have a look at it with you, call me on 0421 284 330
Thanks
-Patrick
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
