hi all,
I am getting an R34 GT-T auto. It dosnt have the factory boot spoiler. I like them and would like to put one on. Are there indents or markers where the holes would normally go for boot lids with them? Just so i know where to drill the holes? if not is there a template going around as to where to drill them?
thanks
Jason
https://www.sau.com.au/forums/topic/318480-fitting-an-r34-gt-t-boot-spoiler/
And if you fail at measuring... Look on the underside of the boot lid and see if you can tell roughly where the spoiler used to sit before it was welded up when the last person took it off.
+1 for buying a whole new boot. There are people who will jump over each other to buy a dewinged boot lid for their Skylines.
LOL i was going to suggest a change over.. but i've been beaten to it.. so many people will swap boots.. however you may be pressed to find one in the same colour
or alternatively, look at getting a 34GTR spoiler..
The 4 door actually came with a few different types of stock wings.
This is the small boot lip.
And this one is the wing that looks similar to the coupe wing, but I have compared the two and the shape of the wings are different. This one sits slightly lower too.
In relation to the initial question I can't help you with that, sorry.
-Jimmy.
so there is no such thing as one of these without a wing from factory? its a 4door if that makes a difference?
Oh, I thought you meant a real R34, sorry. The real ones ALL had wings from factory. Still I'd try and swap/buy & sell. I'm sure some people out there want to de wing their sedans as well. Don't know if the coupe boot lid will fit the family car though, so you'll have to check that out further.
Coupe boot doesnt fit a 4 door.. And others have commented that ia coupe spoiler on a 4 door makes the car look like a shopping trolley LOL
Edited by .:: GimpS-R34 ::.
Origin also make an aftermarket boot lip which is slightly more agressive than the stock one yet still subtle.
It also deletes the centre brake light.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
