hay people the names lizzy , new to the site.
im from the parramatta region & drive a R32. i did drive a r33 before but it was an NA so now ive kicked off the P's and onto the real thing.
hoping to meet other like minded people who have an interest in japo cars. ther also arent that many girls i know who have import cars so it would be nice to meet new people as well.
any questions... i guess, you can ask me!!
Lizzy xxx :/
Edited by Lizzy89
https://www.sau.com.au/forums/topic/318548-hay-im-lizzy/
  • Replies 103
Any mods or is it stock?
Plans for the car, like Track / Drift or just a street daily / weekend car?
ive got a bigger turbo in it garret turbo t70, waste gate, screemer pipe, fuel regulator which makes it sound like theres a bee living in my car every morning, front mount intercooler , blow off valve, i have a shortshifter which im thinking of changing because its a bitch to change, all the necessities except aircon. LOL
ive come on here to see how i can lower the noise of the fuel pressure regulator
and nah i dont really have plans to take it to ttrack, its not just a mess up car, this is my car and the only car i have lol probably just my daily car i guess and street racing when guys wann be dicks
Edited by Lizzy89
https://www.sau.com.au/forums/topic/318548-hay-im-lizzy/#findComment-5205436
Sounds tuff with those mods!
I quite like the short shifters, change gears quicker... Yeah...
You have a big turbo / Screamer Pipe and a Blow Off Valve and you are wanting to lower the noise of the fuel pressure regulator..?
I am surprised you can even hear it when on boost and closing off the throttle when changing gears... :/
https://www.sau.com.au/forums/topic/318548-hay-im-lizzy/#findComment-5205461
well in the morning its just like a static sound like zeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee and then it just stays there, later in the day when the cars warm it goes away, but its usually there wen ur like stationary and then u drive off it wheezes like a MOFFOOOOO and its embarasing everyone stares man. but anyway yes other then that thats the only time i hear it but im more anoyed at people staring me lool
https://www.sau.com.au/forums/topic/318548-hay-im-lizzy/#findComment-5205474
Just tell them it's modified and drive off.
Ppl would stare at me when I had a HKS twin plate and it would make a rattling noise.
General Maintenance Thread is probably the best to post the subject on your Fuel Pressure Regulator.
Someone should be able to help out.
http://www.skylinesaustralia.com/forums/Ge...enance-f10.html
I don't recall fuel pressure regulator's making noise... Stock or Aftermarket one?
https://www.sau.com.au/forums/topic/318548-hay-im-lizzy/#findComment-5205484
aftermarket
yeah it makes a buzzing noise
why dont u come over and help out?? looollz just kidding
https://www.sau.com.au/forums/topic/318548-hay-im-lizzy/#findComment-5205493
i :) watching all the guys flock to a potentiallly female introduction thread..
its like seagulls and fish an chips.. shame on you birds expected more.
oh and it seems sau is dropping its standards.. post 12 and no obligatory PICS OR BAN?
https://www.sau.com.au/forums/topic/318548-hay-im-lizzy/#findComment-5205653
Well in all honesty I visit this section maybe once every 2-3 months and this had alot of posts in it so figured something interesting must be in there. Turns out I was wrong.
https://www.sau.com.au/forums/topic/318548-hay-im-lizzy/#findComment-5205739
Hai Liz!
Were all pretty cool here, apart from Birds, he is a sexual predator who really digs computers and batman.
Probably best to steer clear of Birds, alr33x is ok though as he is gay.
Cheers,
Mr x.
Edited by RBNT
https://www.sau.com.au/forums/topic/318548-hay-im-lizzy/#findComment-5206046
i :D watching all the guys flock to a potentiallly female introduction thread..
I too just noticed the seagull frenzy. Where HAVE our standards gone? No "pics or ban" no "get rid of the chromies"... I feel so let down by you guys.
P.S OP - if you ditch the short shifter - do you want to sell it?
https://www.sau.com.au/forums/topic/318548-hay-im-lizzy/#findComment-5206054
thought you would be in here :D
damn it im in here too :)
https://www.sau.com.au/forums/topic/318548-hay-im-lizzy/#findComment-5206056
