  • Replies 45
No good can come of this video being posted online!!! ACA/Today Tonight etc will have a field day despite no speeds being displayed. The oncoming headlights on Conrod are interesting!
Yep... my description of tools like that would have my post withdrawn. This is not motorsport, can the mods shift it to the tools corner please.
Last time I checked, Bathurst was a public road.
I hope this doesnt encourage any more idiots
TT
LOL...this is funny. Bloody hoons. Put it on Current Affair and give them a good roasting... ONLY... i smell something fishy!
Ok, to clarify ...was it night or morning. I need to know to sharpen my hypothesis :merli:
I wasnt even in the country at the time and I think i know what was going on :( Last time i was up there, all the signage isnt there unless there is an event on / or about to be run/has just been run. Me thinks someone got to do laps before the start (or was it after) of the recent 12hour? If i remember it was wet! LOL, if i am right i bags a steer of the R33 :P:D:)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
