from what i understand, someone had an accident into him, and as he was putting the car onto a towtruck, someone hit the car again
yeah thats what happened. parked car in no standing zone, car into of me hit the brakes to avoid it, i hit brakes and stopped and the car behind me locked up and slid into me pushing mee foreward. then when the other cars had left and the tow truck came for me, the towy backed up and as he was about to put the tray down another car ran into it at speed and rammed it under the back of the tow truck :thumbsup:
Shit it's going to be a tricky one for insurance.... who pays for what?!
Lucky both cars that hit me had insurance. the frist guys insurance told me they will try to asess how much damage was accured in the first accident, dunno how they'll work that one out, the cars about a foot shorter now.
sorry dude. i know where a blue s13 silvia is if your interested. ca18e/auto has hail damage but for $1100 could make it into something good, has hicas, sunroof, original mags, same colour as mine. hail damage has effected bonnet boot, top of doors. windscreen. but for track car, cheap cheap body. i almost bought it last week, just to put back on ebay and make a few hundred easy dollars.
gonna wait abit and see if i buy back the wreck first. thanks anyway :)
  • Replies 185
Posted Images
Damn I didn't get here in time :( This will be the first DECA I haven't raced in since I first started :wub:
Oh well I'll still come up. I can Marshall on the mini wang if you guys like?
Bad luck mate, what broke?
I will take you off the list and bring on the first reserve. All pull outs will be refunded after the event.
Not sure mate. Front of the head is knocking; i'm thinking a lifter, valve spring seat, etc.
Going to also pull the oil restrictors out the block. The combination of N1 pump and 1.5mm oil restrictors is not working for my engine, the head has always been noisy on idle, since the rebuild. Also going to do a couple of other small tweaks; i'm useless, just can't help myself :banana:.
Its not the VCT clicking...?
RB20's don't have that do they? :D
Hey Leon.
I went moto riding with Andy on the weekend. He told me you bought his car. Are you bringing that to DECA? See if it can handle more than 1 run?
Going to also pull the oil restrictors out the block. The combination of N1 pump and 1.5mm oil restrictors is not working for my engine, the head has always been noisy on idle, since the rebuild. Also going to do a couple of other small tweaks; i'm useless, just can't help myself :P .
damm i haven't seen a rb25 do a lifter or a valve spring seat. Does it still run smooth ? i.e not misfire or huge unusual lump in the engine cycle.
RB20's don't have that do they? :)
is this how you humour yourself ? rb20's don't have vct, or a bullshit oil feed going to the front of the head
oh and for the rb20 bashers, look at who won deca last time.
RB20's eat dick russell you know that :P
Campbell
When your RB25 pos beats me then I'll listen to what you have to say :) Actually if it ever makes it to Deca I will!
"cough" the results where rigged "cough"
hahahaha gazelle d's breath smells like Russell's dick
and Dean i'll sort you out on the way to superlap woot woot superlap
Campbell
Not a problem. List updated. Tim or campbell make youselves useful and tell Dean he is in for deca and to pay up :blink: cheers.
Told him on the weekend but will remind him today as we just got back from Superlap last night
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
