Guess I'll save for a decent one then. Cheers, mate.
Eric, some good shots man!
With the auto focus, have you tried focus lock? With those kind of photos, set the focus point to, say, middle. Aim it at the item you're shooting so it locks on (dont frame it, just aim at that point), press the button half way, hold the button in that position and move to take the photo. It'll keep that focus, and save time manually focussing! Its a trick I use cos I'm half blind. Never too sure if its focussed right or not.
  • Replies 193
Yeah, I tried switching from Matrix to point. Problem was that a lot of the nature photos had Crocs behind a few leafs/twigs. I tried shooting a few shots with auto - all crap. Then went to manual and would take a few at slightly different focus - all looked ok through the view finder. Of course, generally all of them were a little off which is why I only posted some of the better shots on auto. I've still got a lot to learn :blush:
You'll get there mate. I've been shooting for just over 6 months now, and I've learn a lot in that time. Just listen to Sam, Sidd and Zennon and you'll be right.
Sam, awesome shot!
Well look who decided to show up... How's stuff over there sam? Nice pano's btw
Hello hello. so far so good! Getting used to a new town but heading off to Europe tomorrow for a month, then back to London to find some work..
Thought I better start adding to these monthly photo threads! So many awesome photos on here, very nice work. I really need to get some practice!
Nice shots mate, I like the graf one with the R33, would look even better without so many reflections in the car though. imho.
How long are you over there for, Sam?
Took these tonight. Not awesome, but definately a start. Technique I can work on:
Next time I might find somewhere with less lights. Or kick them out... Its the guetto anyway, it'd be normal to see people kicking lights :ermm:
Sam can start a 'many cans from different lands' thread :P I'd be up for that. Good to hear all is well dude!
My 50mm 1.8D arrived today. I'm busy packing/moving and I've been working off site for most of the week so no real time to play with it properly.
Here's the only shot i've tried so far. brenizer effect on the car just outside of the garage. Not so sharp as it was all hand held in very bad light. But the technical mumbo jumbo behind it worked well. SO expect something nice over the next week (if i get time :) )
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
