Yeah, I tried switching from Matrix to point. Problem was that a lot of the nature photos had Crocs behind a few leafs/twigs. I tried shooting a few shots with auto - all crap. Then went to manual and would take a few at slightly different focus - all looked ok through the view finder. Of course, generally all of them were a little off which is why I only posted some of the better shots on auto. I've still got a lot to learn :P
Yeah common issue. Best way to avoid this IMO is get in the habit of zooming in on the view finder three or four times depending on the camera and then check what it looks like. You might have to take one photo you know is sharp using a tripod or something so you know how many times you can zoom in on a sharp photo before it doesn't look good any more.
Does that make any sense? lol
  • Replies 193
Nice shots mate, I like the graf one with the R33, would look even better without so many reflections in the car though. imho.
Thanks, Yeah I agree on the one with the graff, will attach the PCL next time to cut the reflections see how it comes out. Cheers
The birds head is soooo sharp, looks great Sidd... The colours are pretty blown on my moniter, the yellow and reds especially.
I think its just the feathers like that. Coz honestly i havnt done any editing to it, well apart from usual raw processing, like brightness, contract etc then change to jpeg.
Will look at the high-res file tonight and see hmmm.. Also i use a IPS panel monitor, and looks fine. Not to sure tho, will re-check. Cheers for that feedback.
Oh and used a macro lens for that shot lol and focused on the eyes only.
Two more:
Edited by siddr20
Awesome macro shots, Sidd.
I've gotta ask, how close can you be to the subject to get a fully-filled frame and still be in focus, especially with a 180mm focal length? I've got a 100mm f/2.8 USM Macro, and sometimes feel as if I can't get enough detail while still making sure the frame's filled enough.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
