i have a pair of rb26 cams in my car with cam gears. the concern that i have is that my car has hardly no vacuum on the boost gauge which i guess has another problem with startingt the car aswell. is it safe to say i would are should do solid lifters???
https://www.sau.com.au/forums/topic/319186-rb26-cams-in-rb25/
You could you know put the stock RB25 ones back in there, save yourself a bit of work and end up with something better.
that or just get some tomei poncams instead similar money to the solid lifter conversion and you end up with better cams (assuming you aren't going to put some massive cams in later?)
Edited by TiTAN
i have a friend that has a set of stock rb26 lifters i may use those cuz i think the rb26 cams are a good cheap upgrade so i want to try it out but i want to do it right.
buying pon cams will probably work out at a similar price when you factor in the labour of setting up a solid head correctly..and will be more of an upgrade.
dont forget you will need to shim the solids to get the clearance right.... and swap out the springs just in case they are a bit soft (common rb25 issue).
so basically i should put my old cams back in and get a rb25 cam upgrade..
What is the rest of your setup?
the motor is stock but its a Frankenstein. i have r33 turbo head with a r34 n/a block currently with rb26dett cams. but those are gonna come out. i have turbonectic t76 turbo with rb26 manifold a/c running e85 with dual pumps an 1000 cc's all put in an s14 shell.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
