Hey guys,
Still tearing down this RB25DET I picked up this week. My next challenge: removing the crank pulley. There's no flywheel on the motor so I can't really shove anything thru the ring gear to hold the crank in place.
So my questions.....
a) what's the thread diameter of the studs that mount the flywheel to the crank? in case I need to frankenstein something up to keep it steady.
b) Am I missing anything with removing that 27mm bolt, other than giving it a good smack with a hammer to crack the seal then just undoing it with the help of a breaker bar etc?
c) Anybody have an ingenious way of securing the other end of the crank, other than by my Frankenstein method above (metal bar with a few holes drilled in to secure it against the crank, then lock it against engine stand)
Thanks guys.
https://www.sau.com.au/forums/topic/319657-removing-crank-pulley-bolt-27mm/
be careful man or you could damage the seal behind the crank.
put the flywheel on then use the bolts where the clutch attaches to the flywheel to tie some shit to the engine with
then yea breaker bar..
There's the problem tho - I don't have a flywheel, at all.
Thanks for the warning about the crank seal.
*Might* get access to one of those - would it be enough by itself to just crack the bolt straight off? I.e. does an air-powered tool deliver enough force to just break the bolt without needing to secure the other end etc?
yep...did it twice yesterday with RB26 engines...they were 350ft/lb tensioned. I do have a good rattle gun though but most reasonable quality ones should be enough for a 25.
The engine should provide enough resistance for the impact of the gun to loosen the bolt.
Thanks, THAT'S what I was trying to say :-)
OK, well the missus' old man has an air compressor, so I guess I need to hit up Kennard's for a rattle gun.... I wonder if they hire them out?
Thanks for the advice guys.
If no rattle gun, take the sump off and use rag covered spanner or such to wedge between the crank and block. (use a counterweight)
Great idea - I have a Bag O' Rags and a big-ass spanner. I'll try that before going for a rattle gun - I'll set the wrench up and smack it with my breaker bar.
ahh yes...before i had a rattler i used the wooden handle of an engineers hammer to wedge the counterweight.
yeah wood is the go try not to use anything thats hardened just in case it slips and centre punches something useful :P
the handle of the hammer i mentioned looks like a crocodile has been munching on it...lol
I got the bastard off.
I wedged a piece of wood between the girdle and one of the rod caps at the point where the rod has minimum clearance from the girdle. Then with the timing belt still in place, I was able to undo the intake cam gear bolt and then the crank bolt with surprisingly little force... they didn't just come right off, but instead of the epic battle I was prepared for, I just had to use a measured amount of force with the breaker bar until they came free. Then used a pulley puller to get the harmonic balancer off, and that was that. It's amazing how easy it can be with the right tools (and good advice!). Thanks guys.
Head came off tonight, tomorrow I break apart the bottom end and see what the bearings look like.... :blush:
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
