Hey Guys,
My car has been off the road for a while now while I have been fitting new exhaust etc etc
I fired it up last night and I have white smoke coming out of the exhaust and milky crap under my oil cap.
It isnt coming out straight away but away a tiny bit it starts. It isnt all of the time either, some times it will die down to next to nothing (this is all at idle).
There is no milk in the sump.
Checked the dipstick - no milk.
There is no milkshake in my radiator, only coolant and water.
I have checked the lowest part of my cooler piping, there is no oil (thought it might be the turbo seal).
I have my PCV blocked with my covers vented to a catch can.
My mods list is as follows:
RB25/30
Type A poncams
Wiseco Pistons
Stock Rods
JPC Stainless manifold
PSR 45mm Wastegate
GT35R 0.82
3.5" Turbo back exhaust
Front facing plenum from dahtone racing
Front Mount
Vipec V44 plug in
Techedge 2j1 WO2
Bosch 044 with 3L surge tank
Nismo 740cc Inj
Splitfire Coil Packs
Am using the shittest oil known to man for now, didnt want to put the better oil in until I have sorted the overfueling. 20w - 50 oil.
I have some fully synthetic 10w - 40 oil to go in.
Please help
PLEASE :P
Sitting in the car now with the laptop waiting to go :)
https://www.sau.com.au/forums/topic/319928-milk-in-my-oil-cap-none-in-the-sump/
This happened to my last car after a MAJOR thrashing followed by a long time sitting.
Nothing was blown but there was a significant amount of condensation trapped in the motor. I suggest a very good and thorough service before anything else.
Mine was fine after I serviced it and ran it at opp temp and driven for a while.
Yep, coz you've sat it for some time, the engine has had some condensation in it, and where does it condense?? the rocker cover so you'll see it in the cap, drive it for a decent run and it should be gone the next time.
Yeh that is what I am thinking. I pulled the catch can off, and have a small amount of hot water right could just near the 90 degree bend but none in the catch can.
I just checked the oil cap again, there was hardly anything milky compared to last time, I was quite impressed.
I have taken all of the catch can lines and everything off and think I will see how it goes with them off, will help get rid of it a little quicker I guess.
What do call a "good service"?
The car was not trashed in the slightest before it started to sit, it was babied and then just sat.
Did a compression test. Results were between 120 and 130 for all of the cylinders, so no drastic drops. I am not sure how accurate the gauge is, but surely it cant be out 60 psi :wub:
Yeah its just condensation. Drop the oil and change the filter and take for a good run . Some cars during winter that dont get a long enough run can do this as the oil doesnt get hot enough to burn the water/condensation out of the oil.
Cheers thanks guys.
The car was run for over two hours today and there is not a sign of milk under the cap any more :P
Nice new fresh oil and some time without the catch can lines on and there is no milk at all :)
Thanks again.
Similar thing happened to me while my car was off the road for a month.. Except the oil turned milky/caramel. Turns out it was condensation/rust in the motor. I bought 2 sets of oil/filters and changed them after around 5 min of idling, then put some Elf racing oil and its been sweet ever since.
Do a compression/leakdown test to be sure if you like tho.
you should see the inside of a motor that has only done short in town driving......it is full of condensation and sludge in all the corners and nooks and cranny's. Some of the sludge is like black putty. All vehicles need a good long drive for a few hours every few months or so.
Why do you think that semi trailers get big mileage [in millions of km] out of their Mack's/Kenworths etc, because they do haul miles not stop and start stuff
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
