1/4 mile question: Few months ago i went to Heathcote for the first time and ran my car 1/4 mile. I did worse than i expected.
Ever since that day me and a mate have been debating our actions that day, and we haven't resolved it therefore i thought i'd ask you guys for your opinions
Car: R33-hiflow turbo, Mines ecu, 16 psi, 2.5 inch turbo back exhaust, split fire coil pack, apexi 3 inch intake, r34 cooler.
The big QUESTION: When i got to Heathcote, my friend advised me to unbolt my exhaust just before cat as "this will improve" the car, car will go better in his opinion.
I ran 14s flat at best, embarrassing, and in my opinion the car didn't run as good, just sounded loud and tough, but i don't think it went any better, if anything, went worse.
So, questions is, DOES UNBOLTING EXHAUST BEFORE CAT HELP? Please elaborate on your answers-some people say no, you need compression others say yes, better flow. ?
Edited by adis
https://www.sau.com.au/forums/topic/320194-14-mile-question/
Unbolting the exhaust won't do sh|t if the exhaust is already free-flowing enough. So unless you've tested it on a dyno to actually be a restriction then i'd be inclinded at this stage to say there is no benefit. (See point #4 further down).
So that part of your thread is largely pointless, so don't listen to your friend anymore me thinks... :3some:
What information/issues there are though... as follows.
1. What were your 60ft times?
2. MPH?
3. Actualy ET?
The above three will give a much better idea of what is going on.
4. You are running a yum-cha ECU/Tune (ie, not a properly tuned setup). It's probably rich as all buggery which is not helping the situation so dropping the exhaust wouldn't have even made much difference if there was restrictions anyway.
So that part of your thread is largely pointless, so don't listen to your friend anymore me thinks... :)
2. MPH?
3. Actualy ET?
Correction, when i ran the car i had 14 psi, and stock cooler and stock 2.5 inch intake with pod. (190kw at wheels)
1. What were your 60ft times? 2.37
2. MPH? 104.02
3. Actualy ET? 14.0034
temp 35.3 C (lol)
-is it possible for the car to be more laggier? Because for some reason the car felt laggy once i took the exhaust off?
2. MPH? 104.02
temp 35.3 C (lol)
Ok so…
1x stock turbo
1x 2.37 60ft
1x 14.0 ET
1x approx 45 degree track temp/35 ambient
Sounds 100% normal to me all things considered.
Exactly what I would expect from a 60ft such as that on factory turbo without a proper tune and decent 60ft time.
The fact you are running 14psi through it wouldn’t have been doing any favours either.
Then add in the factory I/C… high ambient temps… after a few runs it would just be pushing hot air around. It's big fat mess of a situation! If anything running a 14.0 was probably as good as it was ever going to get!
Either way as I said – Sounds 100% normal. Nothing to worry about. Dropping the exhaust just added to the already bad state of tune/setup so no surprise it probably did more harm than good.
check the tune - how well is it tuned? is it tuned enough?
check your tyres (good? worn? new? wide enough?)
check tyre pressure (what was it?) should be 20psi for drag
with the same mods, but stock turbo i was able to do 13.7 @ 105mph with cold track and slipping diff
so it should have been quicker. my 60s were lower and my mph was the same and 1/4 was less
What paul said. I was able to run 13.4 with that mph.
Concentrate on your 60 ft times and your et.s will drop considerably.
  • Nope 1
here is a mines map versus factory... bugger all diff. It is doing jack for you... time for a decent ecu and cooler as posted previous.
I made 220kw on mines ecu, 16 psi, and all those mods. If i was to get a front mount, and get ecu, you still cant go past 230kw due to injectors and z32 maxing, so is it really worth it? ... i thought about it but in the end opted not to waste 1k for 10kw. My current tune is still safe, on 220kw
When i ran the car i only had 190kw and didnt have half the mods. Will be interesting to see what i get now, with exhaust on.
average power makes the car quicker = quicker 1/4 time
peak power in one spot means nothing
on the street you car would be ass to drive, it would lack power and midrange
with a full tune, intercooler and real ECU the car would fly
your on crack if you make that much power (cant be nice power either) on a r34 SMIC... its a time bomb. I hope you monitor your ait's.
10kw peak?
Or how about 20-30kw through the midrange? That is certainly worth the money of a FMIC ($500) and ECU/Tune ($1800). You don't need to get injectors or AFM... and hell if you get a PFC etc you can tune past the AFM quite safely anyway within reason.
That is where the real gains of a proper ECU & tune lie, and that is what will make a car fast.
The Mines tunes generally are only marginally better than factory in most cases - they are super fuel'd and hurt the midrange power signifigantly as a result.
Yes they are "safe", but an aftermarket tune can net
1. Better economy
2. Better mid range/transitional power
3. Better peak power
#2 obviously being the biggest improvement and you'll easily notice this driving it after a decent tune is performed.
also wouldn't call 16psi out of a highflow turbo running though a r34 SMIC a 'safe tune'
Probably the only saving grace is the Mines ECU doing its super-fuel up :thumbsup:
Either way i agree, running that much boost is asking for trouble.
After a good 15mins hard drive on the street with sufficient heat soak and so on it's probably just luck nothing is really going wrong.
Cmon man you wanna have your car running decent times and you dont want to get a decent ecu and tune a front mount, thats one of the first things youd want to get let alone looking at your suspension and tyre issues after if you want to improve your times even more.
Im on crack? ill ignore that just be careful my friend...im not here to insulted, just asked for opinion.
I took it to a tuner like your self, he chucked it on a dyno and thats the result i got.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
