maybe I should look into the OEM kit as well... The quality of the hose kit I have seems to be ok though.
Chris: The rust - basically its all in the pics.
  • Replies 127
Posted Images
@ Chris - Basically do the good old screw driver test on the sill. You'll see if and where its buggered pretty quickly. I found that mine had rusted through a couple of panels near the dog leg. I dont know if its common for them to rust out around the wheel arch. Mine looked like it had been dodegied up in japan.
Just be prepared - once you start digging you might find shit you dont want to deal with!
This car is in Holsworthy? and i didnt know?
Mine is one suburb away. If you need some ideas for what to do next lol
Also if you change your mind about pulling the engine i can help you do turbos in the car, its not too bad a job just takes a while.
Cheers Jeff! Would be sweet to catch up at any rate! The engine is definately coming out - I just seem to keep having set backs... My mechanic's father just passed so this week is out, and most likely next week as well... The gearbox is getting a freshening up...
Whats done to yours?
im loving this
i should say hi next time i drive down to sydney
The car spends a lot of time in coffs harbour if you want to come a little less of a drive :) I work there Tuesday -Thursday every week...
Quick update:
Due to the amount of driving I do I wanted a slightly more comfortable pew to park my fat ass on. I bought a pair of 32 gtst front seats and through the drivers in. Well, I am honetly uncertain if it is very comfortable - its hugely high compared to the gtr one. I think I'll be switching back to the gtr one soon.
Engine out update - 11th october. Box and engine will be out and the upgrade done. box is going to get a freshen up to. Will post pics and mabe a diy for pulling the engine and box.
know your pain mate i had the same drama in my 32 gtr especially if you had to drive a long distance for me it was 3hrs both myself and a mate get very uncomfortable after the drive.
I have been looking into a couple of options for seats. I would love to go with a VELO seat, but I cannot find a reclinable one (they're ADR approved).
All the other comfy quality seats are not ADR approved - well at least none that I have found. I wouldnt mind some of the OMP seats, but again I run into ADR compliance issues. I dont want to drive around with an illegal seat in the car as it attracts enough attention - and luckily I havent had any issues with the boys in blue since owning the car.
I had a commodore for a daily before and it bored the living crap out of me... I am willing to pay for a great pew to park myself on, just have been caught so far... I could be like you and buy a twin turbo supra to cruise around in :(
I'll find one soon I hope... I will enjoy it more once the engine is complete :)
I finally got off my arse this weekend - well kind of, was pretty sick but have wanted to do this for ages.
Before: The unpainted grill
After: The painted grill
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
