Another win! :happy:
The JZS171/UZS173 Crown and Crown Majesta are now eligible in both sedan and wagon versions. Eligible motors are 1JZ-GTE and 1UZ-FE. This one actually took a fair bit of work to get through, but we got there in the end!
Remember it's still early days, but it does mean we can start work on getting plates for them, around 12 months away.
https://www.sau.com.au/forums/topic/320451-new-to-sevs-crown-sedan-and-wagon/
HMMM ive been waiting for these JZS171w Crown wagons ....... for all those who want to know they dont come in V8 form for the wagon 3 variants are 2.5NA 2.5 turbo same as chaser and 3.0NA
the turbo Variant you want is called the Athelete V all these are turbo.
Only the majesta Sedan come with V8 2wd and 4wd version
Good work Kristian for this....... and what was the problems you encountered to get them added ?
Sorry mate, got confused about which comes with which engine... one more time for the dummies??
1UZ-FE V8 - sedan only
1JZ-GTE - sedan and wagon
Phil, the Crown/Crown Majesta/Crown Athlete thing confused them a bit, as did the fact that I didn't bother listing a few engine variants because the chassis numbers didn't match up, hence they're referred to as S17 series in the application...
Edited by Iron Chef
Nope you'll be looking at $20K at least I suspect - they were a 5.5 million yen car when they were released...
Phil probably knows better than I do, but if you want black, expect to pay shitloads more.
OMGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG
12 months away?!?!?!?! i have been wishing for these for AGES!!!! i'll keep my soarer for a little whlie i think... the soarer that i don't have that is.. haha
these cars are AMAZING
can't WAIT!!!! keep us in the loop
Unless under way already unfortunately this will more then likely end up on the SEVS list and go no further, Kristian does the work for people to get them on the SEVS list then no one buys cars as no workshop wants to commit to a new unknown model no matter how good they are.
Some business have screwed some workshops so much they are closing down or will not spend any money on test cars for quite a while. If people paid a fair price for compliance there would be money in the bank for test cars not just enough money to get by (not all workshops).
Dunno much about them (yet), which build years are eligible?
hmm... love the thought of an AWD twin turbo V8.... if only Toyota could figure out how to make a nice interior
Edited by iamhe77
Is the hearse spec one a longer tail or can you actually fit a coffin in the boot of a standard Crown?
If you can, that's an awesome selling point. Substitute coffin with 2by4 or surfboard depending on the client I suppose.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
