  • Replies 48
Yeah you can't see what the back pressure is doing by looking at a dyno plot - sometimes it can show up as the power falling over prematurely due to the tuner having to pull timing to avoid detonation before MBT. Funnily enough this dyno plot looks like what you could expect to see in that case, if it weren't for the claim that the early drop off is due to wheelspin. Silly rolling road dynos...
Will be interesting to see how it goes on a hub dyno, and how the engine/turbo lasts at that power level if its going to be used on the track at the power level at all?
At face value, very nice power level and spool for a convenient and affordable package :blush:
Didn't Mafia make over 300wkw with a .63a/r GT3076R?
I think it was Geoff Raicer (of Full-Race fame) who once commented on a forum that torque starts declining when ex manifold pressure exceeds intake manifold pressure in a turbo setup. I guess this makes sense as it is at this point the VE would start declining resulting a drop off in torque and therefore hp. Hopefully the decline doesn't happen too rapidly resulting in a short torque/powerband.
The aim of the game is to get torque to build as early as possible and hold it flat to the redline - easier said than done with smaller responsive turbo's.
That was all the way to rev limiter. Drop off was mainly from lose of traction. Sam did not back off early. You can double check with Sam if you want.
The Main point is that we've managed to controll and hold boost all the way to 18psi using an internal gate setup on a .63 turbine housing.
and
This turbo has made the most power out of all the R33/34 high flows there are with 98 RON Fuel.
This is a very BIG claim that is untrue.
My car as a hiflow turbo form Adelaide Turbo Services and GCG and has made 298.2RWKW and couple of years ago and will be going back for a retune in a few weeks.
Cheers
NutR33
except your are runnning RB27 stroker and this is a RB25 stock. Also not been straped down.
strap down or hub result is going to be soo interesting to see. can't wait. :devil:
strap down or hub result is going to be soo interesting to see. can't wait. :ermm:
+1 :D Cant wait to see more results!
I will be getting a high-flow done with tao so always good to see recent R&D
Cheers
NutR33
Has this been run on other dynos? or was it a one off?
I would also expect a bit more than 116mph from that power figure, been that Ive run and many others have too, 105mph with 180rwkws
Just the same way 2 turbos can make the same peak output and completely different delivery, 2 tunes can do the same.
He might have the numbers, but might not have the torque to get the MPH down. The ET sounds about right for the car and MPH.
Torque wins races, pulling timing and fuel doesnt.
"This turbo has made the most power out of all the R33/34 high flows there are with 98 RON Fuel"
Sorry but i didnt see anywhere in his claims that it was the highest power figure on an RB25 or any other motor or level of mods.
  • 3 weeks later...
hey guys well i finnaly took this turbo of Toa, and let me tell you this its runs amazing!!!!!!!!!!!!! now all i need to do is get a tune!
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
