ok guys, so my car is missfiring and i dont know why...ive upgraded my coil packs to split fires and my spark plugs to iriways which were like $36 a pop and were recommended on the forums and are only like 1k km old ..so whats next? im thinking of just cleaning the coil packs and giving that a go and also i dont have a cover over the coil packs and i heard that lets moisture in? so i might search for one because i have my car booked in for a tune next week :devil: any help would be great. thanks
https://www.sau.com.au/forums/topic/321356-yes-another-missfire-thread/
running 12psi but it spikes 14psi, i got the ngk iriway spark plugs they come already gaped at .8mm.....im guessing maybe its because i bought the split fires second hand...but ive had them for like 6 months and no problem..im hoping its not the coils, and not the spark plugs lol because ive spent heaps on both of them. its not a really bad miss fire, just a few pops
no i havnt had it washed or detailed, only when i have it on high boost it will pop when hitting 5k rpm, on low boost might pop a tiny bit. i heard wrappin ur coil packs in silcone works, wot kind of silcone do i use?
Well that depends on the purpose of the silicone. Are you trying to retard water and keep moisture out? Are you trying to make a seal? If you're trying to keep water out, get a silicone which is safe for plastics(some of them have harmful fumes which can deteriorate plastics).
Did this start all of a sudden? Did you change anything? Is your engine running rich or lean? If its rich its unburnt fuel, if its lean, it could cause popping and it could mean your fuel pump is failing and falling behind when hitting high boost.
sounds like the stock ecu trying to protect your engine from too much boost, it will probably go away with the powerfc fitted.
ok so i was bored at 1am and decided to pull apart my engine bay, i took out the coil packs and cleaned them with silcone spray coz they were WAAAY too dirty all over....pulled out the spark plugs, and i noticed 1 spark plug had alittle hairline fracture on the side of it, but because i didnt have a spare spark plug i just put it all back together n thought id give it a run...and now its not miss firing, could cleaning of the coil packs make it stop miss firing? and should i replace that 1 spark plug?
If it missies again its because its hitting 14psi with 1.1gap and just use the cheap copper ones if gona be running more than 12 psi get yourself a set of bcrpre7s like $3 each and they come gaped at 0.8 and that will not missfire under high boost. But yeah could of been just maybe the sparkplug was to loose or the coil pack wasnt on the spark plug well if its gone now.
This is most likely your problem.
If I remember correctly, stock ECU will have hissy fit when you run more than 10psi boost.
Get PFC tuned, it should solve the problem.
they arnt cheap spark plugs bro, they r ngk iriway7's $36 ea gaped at 0.8mm, i think it was because they were abit loose or coz the coil packs were dirty coz now its working fine :S.
Nah im saying you should use the copper ones there the best at the end of the day. The iriway and all that is just waste of money for no gains.
oh ok, well thanks for that..if it starts miss firing again i might go those then
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
