I have a problem with magpies landing on the roof/sunroof of my car and literally sliding down my windscreen like its some kind of ride..
they have started leaving small scratches on the paint work between the sunroof and windscreen of car and also started to peck away at my sunroof mouldings..
I replaced all my wiper blades today due to they have grabbed ahold of them and ripped them so they resemble long worms..
Does anyone know of any kind of product i could apply to the area to stop them in the mean time while i work out how much it will be to replace the rubber around the sunroof?
someone told me just spray some poison on it.. but then again I dont know if it would dis-colour the rubber area or if it would damage it...
:D
https://www.sau.com.au/forums/topic/321776-bird-issue/
Bitter agent might work. We bought it from the vet to spray on my dog's wounds after an operation so he wouldn't pick on the stitches. I accidentally got some in my face and it tastes RANK. We have also sprayed it on furniture after he started biting the leather couch and it didn't discolour anything.... perhaps try it on something inconspicuous first like on your tyre sidewall before you put it on your sunroof rubber. In any case the rubber's already chewed so you got nothing to lose if you discolour it...
https://www.sau.com.au/forums/topic/321776-bird-issue/#findComment-5249314
lol well all these ideas are good but lol i dunno how ima get a scarecrow to stick to the roof! :D
lol maybe conbine and make an electric scarecrow!!
im thinking car cover might be the best bet - problem is at the moment its parked on a street in a quiet suburb and no were else to park due to garage is full
otherwise it would be garaged :)
https://www.sau.com.au/forums/topic/321776-bird-issue/#findComment-5249601
Yeah also even though a car cover is a good idea, I never bothered to put one on my bike let alone a car, who can be stuffed! Maybe just a little cover for the roof that you can lock in with the doors? Quick and easy and will probably do the job
https://www.sau.com.au/forums/topic/321776-bird-issue/#findComment-5249611
Drop by springfield road, i can share my garage, i just need help to move some stuff =D
https://www.sau.com.au/forums/topic/321776-bird-issue/#findComment-5249615
yeah thats exactly what i was thinking for tonight Charlie, get a tarp / blanket of some sort and run it from passenger side window over top of car and in drivers side window hoping it keeps them off it :D
bloody drama's! :)
https://www.sau.com.au/forums/topic/321776-bird-issue/#findComment-5249618
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
