Hey guys i have been quote for replacing for my fuel filter at 220 at Midas, thats quick heaps for me as my wallet drying out soon lol, do you guys ever been changing your own fuel filters yourself? i thinking of doiing it myself so before that i want to know what i should know. its for my R33 series 2. Cheers guys your help much appreciated!
https://www.sau.com.au/forums/topic/321819-replace-fuel-filter/
220 to replace fuel filter!?!?! mate that's heaps, definitely do it yourself...
the filter itself is about $30-35, all you need to do is undo the hose from each end of it and pop the new one in. very easy to do, can get a bit fiddly if your old hoses are hard to pull off but it's not that bad.
good luck
Cheers guy, it is just that easy. thanks heaps for the comment and i wiill give it a try tomorrow. yer i think that guy was try to rip me off with that price, will let you know if i have done it. much appreciate for the help!
turn the car on so its idling, then pull the fuse on the fuel pump and the engine will stall
that way, you will have less fuel pressure in that line and less splirting out everywhere :)
Edited by snozzle
Check this out if your having trouble.
http://www.skylinesaustralia.com/forums/Re...l&hl=filter
Workshop should only charge you 30 mins labour plus the filter. So all up should be about $60 to get it done.
My missus just paid $250 for an aftermarket WRX turbo intake pipe, because her stock one had rips and holes etc.
I wz lyk siiiigh, y dnt u jst get a gud stock one frm a wrekr 4 lyk $30 an ill install 4 u babe?
Stupid mechanics at her work think they know best... pfft. Then again they are installing it for her no charge. Then again they've had her car for a week now.
What I'm trying to say dude, is that you should get your boyfriend to change your fuel filter for you :rofl:
Edited by SKYRYAN
im confused... 220 to put in a filter?
Man i can change a fuel filter in 5 mins or less... and they cost like 30 bux....
Thats like 5 bux labour LOL 35 bux total.....
the most simple shit and people get suked into paying top dollar.. its so depressing...
What I'm trying to say dude, is that you should get your boyfriend to change your fuel filter for you :rofl2:
lol may be I am too gay to fix the fuel filter haha yer probably go to autoworx if they give me a good deal! Cheers anyway mate
a good answer, this you should ask Midas or any other garage that don't fix Japanese car, they are the best charging the rip price.
if you do end up paying someone to do this for you may i suggest you atleast ask them to show you whats required to do it.
it really is that easy, you would only need to be shown once and when you see how its done i can guarantee you will never pay for it again.
You're still going to pay someone?
This is depressing.
I remember a while ago, a guy on here had a window smashed, payed like $80 for the glass, and another $50 to fit it? something like that ... literally, 5 mins, in and out, tops...dunno how the f**k people justify spendings like that..
that could have been me... had the rear screen smashed with a brick..
150 dollars second hand rear windscreen... which i removed from the car it came out of.
then i installed it into my car.
If you still havent changed the filter.. go boil a kettle... make a coffee.. then pour the rest of the hot water on the hoses that connect to the filter. the rubber will expand and the hose will come straight off
cheers anway man, I think I would give it a try this coming week. It seems so easy for you guys lol I wouldn't mind if I give it a try. I hope I won't stuffed it up lol. Will let you guys know
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
