I get a small shudder in the steering wheel when I'm going about 110km/hr. The first thing that comes to mind is wheel alignment, but it's had two wheel alignments + balancing done on all four wheels in the past couple of months. (It has had two because the second was an accident buy the mechanic, he thought I asked for it when I did not).
Apart from it being a wheel alignment issue, what could cause this?
https://www.sau.com.au/forums/topic/322650-shudder-in-steering-wheel/
Does it shudder when at 110Km/Hr at constant speed, but doesn't occur if accelerating/decelerating through that speed?
If so, check for weakness in the middle of tailshaft perhaps. I'm not sure if the GTS-T has a 2 pce tailshaft like the GT-R though.
Other than that, check engine mounts, front suspension bushes, rack (with leak)...
I’ve got the same issue on my other R33. Happens around 100-110km/h. I’ve got new tyres, had the wheels balanced and aligned over 5 times so far. Over the many visits back to my local tyre shop they found the wheel nuts were not correct discovering they were not tapered enough so the wheel was able to wobble at high speeds. Changed all of them which made a small difference. Next thing I found was the tie rod ends were stuffed causing play. Replaced them and the shuddering reduced however didn’t fix the issue completely. Found the tension rod bushes had started to perish, however after replacement only a slight improvement was felt. I’m still trying to find the issue. I’m going to swap my front wheels from my other R33 to see if it’s the wheel itself. Perhaps check the parts that I have mentioned for any wear or damage.
alignment and wheel balance. doesn't take much to knock out a wheel alignment.
check caster bushes. tie-rod ends for replacing and steering bushes. then the rest of the front suspension.
tried hubrings to help locate the rim to the hub?
This^
Good possibility particularly if you have aftermarket wheels as they rarely ever come in exactly the same bore size as the standard Nissan hub size. Suspension place told me that these hub rings/spacers have solved many a wobble problem. Trick is to get a set of vernier calipers and measure your hub size and wheel bore...I'll be doing this soon as I also have a wobble and have had my wheels balanced already.
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
