Hi guys, in regards to my old thread;
http://www.skylinesaustralia.com/forums/Rb...25-t321488.html
The pistons/crank/rods were dummied up today and have found that the RB26 pistons (using standard ones as dummies), the dome part is hitting the head.
i am using a RB25 NEO head which i believe has a smaller CC compared to R33 RB25 head.
Is it possible to either:
a ) machine a RB26 piston dome flat (will be using ACL pistons, pending budget so will either be forged or cast items)
b ) custom make a piston with either a dished or flat top to suit with RB26DETT/RB25DET compression ratio - 8.5:1 to 9:1 range? (If so, who makes custom pistons and approximately what cost would i be looking at for a set in either 1) forged 2) cast)
c ) custom thick headgasket to help make it clear with RB26DETT off the shelf pistons?
Here what happens when the off the shelf RB26 items are used, you can see where the valves hit.
http://forums.nicoclub.com/rb26-crank-rods...io-t475298.html
Ideally i would like to keep this head and not change to a R33 head which will require rewiring, different injectors,cams etc.
Any help much appreciated.
https://www.sau.com.au/forums/topic/322949-piston-clearance-issue/
You can get CP pistons made which take 4-6 weeks. I'm trying to find out if anyone else will aswell.
Speaking to a few machinists/engine builders; getting the combustion cambers machnied and running a thick head gasket (2mm) they were still getting big compression.
The only way to do it properly is to get pistons made.
Edited by aleks
Almost any piston company will make custom pistons. Not cheap though and from what ive read you're trying to do all this on a budget.
For a start, there's Mahle, JE, Wiseco, Arias, CP, Cosworth, ACL etc
Id start at ACL then try CP, or if the budget allows about $1700 call Specialized Piston Service in melbourne
I've checked with ACL, they dont make it anymore.
I will be ringing & emailing a few companies tomorrow and hopefully get something sorted soon so my car and be completed. waiting 4-6 weeks for them to could is very time consuming :happy:
If custom pistons is the way to go then thats what ill be doing.
so i assume machining the dome is a no go?
Is the dome hitting hte head or the valves, you can easily get the pistons flycut to clear the valves
The dome is hitting the head. Will "flycutting" affect the pistons strength/integrity at all? Who can do this sort of service, the bloke machining my block?
is this a neo only problem? any reason you cant use Rb25 psitons to suit a neo or is there nothing available?
interested as im looking at doing a build down the track.
I am using RB26 crank/rod & pistons in a RB25 Neo block.
You can get it to work straight up with a R33 RB25 head as it has a bigger combustion chamber - 63cc compared to 50-51cc.
do any companies make dished pistons for RB26?
hopefully swiper the fox see's this and put some input into this :happy:
I will be ringing & emailing a few companies tomorrow and hopefully get something sorted soon so my car and be completed. waiting 4-6 weeks for them to could is very time consuming :)
Give quantum racing industries a call up on the south side of Brisbane. They are the main importers and distributors for the CP Piston range.
07 3290 5911
Wait, I want to know how that happened.
How long did the motor run for before you found it like that? that looks more like detonation damage than it does valve damage.
Here's what happened last time I saw a piston touch a valve:
And I imagine if the piston was touching the head with the dome that the dome would have damage on it... but from the pic it doesnt seem to have much of a mark on it..
Also, if that was touching, it would have nuked itself within a few seconds of running.. more so that eating abit out of the piston crown.
Would really like to hear more about how that happened.
Titan - why not? i guess this forum is no good for info and input from other members to help others out then.
GtScott - that is not my piston. just some other bloke i found who did the same thing in the us. if you look closely at the picture towards left side of the piston, you can see circle marks from where the valves hit.
200 - i'll be contacting them today. thanks for the details :)
So from the top of your heads, are there any off the shelf items for rb26 that are dished and not dome?
Forget about rb26 pistons. HIGH COMPRESSION
Lewis engines have Arias pistons for RB25/30 neo heads and engine listed on their site for $1375
Just spoke to quantum racing and they want ~$1520 to get CPs made 4-5 weeks they said.
About to call lewis engines see if they have anything in stock....
Edited by aleks
im not a fan of the arias gear, i would spend the dough on CP's or JE for sure.
I emailed rocket industries for Aria items. hoping they may be able to supply a 26 piston with dished head if not then a price on custom units. i'll contact lewis as well unless you beat me to it.
alek- are you doing 26 internals as well or just 25 neo?
would be to use a 25 piston with the 26 rod since the rods are the same?
hopefully swiper the fox see's this and put some input into this ;)
Doubt it, Admins banned him..
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
