  • Replies 46
sorry 2km/hr then.... same diff.... hardly being dangerous either way
Dangerous? You can't deny that it is more dangerous than 2km/h less.
We need to remember that the speed limits are chosen with the lowest common denominator in mind, ie the worst foreseeable driver, in the worst foreseeable car, driving in the worst foreseeable conditions.
If anyone feels uncomfortable about being caught for breaking the law, then they should avoid breaking the law :)
So I started this thread to warn people where these cameras are because there are new ones comming up every day and there is minimal signage, and it has turned into a "don't speed" rant and some idea that 2km/hr over is not bookable???? It is currently bookable but they are callobrated to 3km/hr over the limmit for the time being, do 2km/hr over the limmit past these cameras after August and we will see how long you guys keep your licence for....
FYI 2km/hr over the limmit by a callobrated machine in NSW is going to be a bookable offence, point to point has been using 2km/hr as there minimum guide for well over 3 months now. The reasoning behind it is if there is a doubt from the machine that they need to give a buffer zone for faulty readings, then they are implying the speeds caught by these cameras are not accurate and therefore can not be used. This is comming from the mouths of one of the head honcho's in the NSW RTA of which I am on first name speaking terms with.
Every one of us goes a few km's over the limmit with or without knowing, past cameras or not, if you are not aware of the cameras and your just cruising at the limmit and just happen to creep over the limmit past a place you didnt know was a safty camera then your rooted right?
I'm not sure if some of you guys have noticed the safety cameras with their single tiny sign that blends in with other signs, there is no more 3 sign warnings with this type of camera so to say "don't speed" is pretty stupid, if you know the camera is there then you definately won't be doing near the speed limit let alone speeding.
I don't think there is any need for the smart ass "don't speed" comments then, when I go past a camera I make sure i'm doing about 5km/h under the limmit just to make sure because it's not worth a fine through a bump on the road that knocks my foot down the tiniest amount to push me over the limmit or incase the camera is faulty and mistakes 60km/hr for a higher speed, or even the accuracy of our speedos. If you don't notice the camera is there that tiny buffer zone is your only chance, and that buffer zone is about to get smaller.
Sure we shouldn't speed (even 1km over the limmit), but this isn't about purposely speeding, this is about cruising at the limmit asif nothing is wrong and not noticing a safety camera and you happen to just coast past a camera a few km's over the limmit, or from years or even decades of doing the Yellow light dash? Isn't it better to know about the camera now on this thread rather than getting a fine in the mail or possibly having an accident from speeding through a safety camera? a fine is too late if you've already had the accident isn't it?
^^^ I suppose Tom, that if all the above is true (and I have no reason to doubt it), a car owner needs to accept responsibility that the rolling diameter of his rim/tyre combo (or more correctly the tyre rolling circumference) should NOT carry an overage - otherwise the speedo will UNDERESTIMATE the actual speed.
http://www.themotorreport.com.au/50423/nsw...-to-570-million
New cameras being introduced next month.... where is the guy who thinks the government will not spend in upgradeing their equipment when it comes to revenue raising? If I were you i'd be selling my radar detector if I were you as it will now be useless, and with a new order of speeding equipment comes a new range of detector detectors.
Atleast they are putting more money into roads that we desperately need and giving the cops a small pay rise
To bring this thread slightly further adrift, I do wish they would fix up the roads....especially parramatta road lol
You're from Melb. and you noticed?
We try and keep that thoroughfare a secret. :thumbsup:
sydney by far has the worst roads compared to other capital cities in OZ (but i haven't been to darwin).
I thought Melb/Adelaid were best
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
