  • 2 months later...
Got the wastegate actuators and fitted em up. Was a real pain to do as there is no room, but all good now.
Also got a hold of a nismo cat converter to help free up the exhaust a bit more. I'll fit it up when I can be bothered crawling under the car again.
Sway bars have been ordered in too. :P
Love the work. Was wondering what are the benefits of replacing the wastegate actuators? or is it more of a preventative measure?
I always seem to get a bit of wastegate "flutter" under light acceleration (0.2 - 0.4 bar), even worse after a cold start. and so it stutters and bogs down unless I accelerate more to bring on higher boost.
Does that make sense? It's hard to explain but that's the best way I can describe it. I've read around of people having similar problems on rexies, and some suggest tightening the actuator arm. Is that possible on our skylines?
Thanks Owen!
Only if you replace the actuators with adjustables or get some with a higher spring setting.
I replaced them to get a more stable boost at high boost settings. The standard one's tended to drop in the mid-high range of RPM.
I get the same problem, but at highway speeds in 5-6 gear at light-medium throttle up hills etc.
One fix is to weld a divider into the 'twin turbo pipe' to smooth the airflow from the two turbo outlets. I am yet to get that done.
Some say they get it tuned out?
Well, I'll be seeing you soon then Chris!! That's exactly what I want to get done.
Another piece of the puzzle done now. Got the rims I wanted to get that 'look'.
Genuine Volk CE28N 18x10.5 +18 in gold. Got 275 35 rubber on them. Next plan is to lower it 20mm.
Care to tell where you sourced the wheels from
CE28N looks the bizz too
Ya, it needs some lowering badly
Well done Sean, the car looks tuff with the wheels.
I'm kinda regretting selling them now....
You running any coilovers??
Also have you contemplated colour coding the spoiler between your bumper and lower lip?
It would give it a more aggressive look and seem like the car sits lower aswell....
Very nice car mate, credit to you......
Yep, got em off JAGR33. Wanted them wheels for a while and kept eyeing them off.
Thanks again Jack!! They are a bloody nice wheel! I will not scratch or abuse them, and I'm also going to organise center caps too.
Also importmonster seems to get in some hot wheels in every so often too. They had a different set in silver a while back, but I didn't have the dough at that time!
Still the stock Vspec coilovers, but it will get something good, in time. I have a set of HKS coilovers ready to go, but I don't want a harsh ride.
Was thinking about colour coding the mid lip but I'm still partial to the black look. I do have the paint ready to go though!
Spent a day on the GTR, fitted HKS suspension and brake deflectors. Rear seat scratched the interior trim so I'm :domokun: at myself for that, scratched pretty bad so may have to get another trim panel.
Also pulled of front lip to colour match to car so I will take pics of new stance once finished!
Yep, it's cheaper than getting discs at the moment lolz.
LH rear coilover is knocking, so that was a great buy.... :angry:
Painted the lower lip, but the paint I mixed was probably the wrong tin as it's slightly pink? I'll just take it to a painter next time I have it off.
Pics soon.
Ha ha, yeah, damn guys wanting engines built.
Hey Steve-o, looked like you got into some trouble on the day lol. When I get the car sorted I'll go. Would of loved to go, but no cash and was working on the R :) I think I like the lip painted, fills it out!
This is lowered to around 115mm on front lip, I like!!
Hey Sean
What did u do with painting.. you go the whole compressor and gun?
I know how to spray but not how to mix.. so i might require your mixing skills if i hire a booth and do a respray later in the year
That looks heaps better!! Middle lip painted white and with the coil overs makes the car look much lower to the ground.
Top job, well done.... :thumbsup:
P.s are they CSC brakes?
Thanks, I love the stance but not the ride quality. Yeah they are CSC 356mm discs with 6 pots. Need new discs though, these are stuffed. Got to find out who sells replacements.
Re spray Dave? Your car looks fine?!
I wore the sperm suit on sunday and whipped out the air compressor and my spray gun. Mixed up DG 2PAK white that I had colour matched, with hardener Added thinners but I probably didn't need to. Primed the lip then 800 sand to make it smooth, then 1 light coat, then 2 coats of the white. Nice and smooth/glossy straight out the gun. Fitted it that arvo.
I'm still learning, but I'm pretty good at painting now :thumbsup: Practiced a lot with a spray can when I didn't have a compressor and gun.
Prep work is still the most important, little things like wetting the floor etc.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
