i reckon its an S13 the rear quater section looks like an S13 and looks like its 4 stud and if you look carfully to the fire fighter on the left i reckon its an S13 front side indicator :banana:
Edited by lookingforboost
Yep noticed all these things :banana: Thought the door trim was a good enough giveaway though.
Anyways, this thread isn't really meant to be about what car it is :banana:
Yep noticed all these things :D Thought the door trim was a good enough giveaway though.
Anyways, this thread isn't really meant to be about what car it is :bunny:
yeah it is :(
deinatly has to be a s13 (i dont think its an NX coupe because it doesnt have flipy up headlight)
Also found a picture before the hack job.
http://www.abc.net.au/news/stories/2010/06/01/2914727.htm
Serves him right for steeling and speeding on paramatta rd too probily in the wet =\
Edited by central coast person
On the up side, the theif might get caught on this occasion :D
Sucks for the owner though...
Might? I can see the driver in the car! =-o
Damn! That's a fair crash. =-/
I don't think anyone is worth getting hurt or ending up dead over a car. I'd rather see the cop chase called off and the thief walk away. Remember the police chase in Canberra that happened a little while back and wiped out a young family. This could have been much worse if there were other people around.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
