Cube wheel options
60 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 114
I really like the CE28N looking rims in the middle of the last set on Mukyboy's pics (the maroon car) .... or the Meisters - (possibly get them mirror polished all over) - would look tuff on a black Cube!
Agreed!!!!
I'm likin the VIP style. Lets face it the thing isn't gonna be fast (thats what the EVO and 34 are for :blink:) so why not bling it up a bit?
If you don't mind spending up, Fabulous do wheels ('Profound' I think is the rim style) in pretty much any size/offset you could ever want.
vs-xx if you can find em in sizes small enough. (im not bias or anything :blink:)
otherwise meshies. get em polished then get the cube slammed with a bit of camber... would look hot as on a black car.
Edited by SkyHi_33
I don't know many sets of Panasport F1s in Australia :)
Maybe I'll get the Meisters, paint them black and get [NVMYCUBE] on the plates....
meisters, yes.
those plates though...
i agreed on the maroon car :)
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
