I have just put in the latest drag version of the os giken box, Something my tuner says his never seen before he said it was a new type, The gears were huge he claims, Alittle noisy but im not worried. Neways Now this happens very rarely usually in the first 3 gears, As im booting it a miss a gear on the odd moment and the revs go through the roof 8-9000rpm, Is that harming my engine? I have stock internals but everything around i have modded cams, injectors, pump, PFC bla bla and the rest , only thiing i need now is the internals done. But neway i just feel like i've hurt the engine in someway and i get realllly shitttyyy when it happens as this car is my pride and joy, What harm am i actually doing when this occurs?
Your motor should have a rev limiter still so damage to the motor would not be something crazy, although standard oil pumps and rev limiters dont go hand in hand with the RBs.
Another thing to note is that when you do that you are flaring your clutch, this will kill it alot quicker than it should.
Its all timing, it shouldnt be an accepted out come that you 'missed a gear'. Try driving fast in slow motion, sounds ridiculous but it works.. After a while ull get into a nice groove.
GL
Ty 9500 on a stock engine with N1 turbs! then you are getting somewhere, accidently saw that when I first got my 32, had fcon v pro computer.
I never had any troubles when it went that high. Just don't limiter bash, that kills oil pumps!
haha hates when it happens! Nah i never limit bash
Edited by GTRAAH
GTRAAH you should clarify what box you've got.
OSGiken make more than one gearbox option.
I'll guess you have a 5spd kit that goes into your standard gearbox case. When you say latest drag box, people will assume the OS88 is what you've got
Sorry to hijack but kinda on topic, with regards to limiter bashing. Would a launch control like the gizzmo set at a much lower rpm say 4-5000rpm put stress on the oil pump? If someone can explain why as well that would be great
cheers Pat
LOL i do know how to Drive!! no one is perfect mate it happens! 20k??? wtf no yes i think n1gtr got my drift its 5spd kit that goes in the casing Mark at hills said there was a street version and drag version and i have the drag version. He said he has never seen this one before must be new.
yeah dude the gears in them are pretty massive ive ordered the 5 speed drag version myself
did u get it with the input shaft as well??
there rated at 800hp i think so u shouldnt break it with a stock motor i dont reckon
I was told they can withstand 1200hp this guy they know had the same box and he has done PLENTY of 9 sec runs in it, and still solid. Is the gearbox meant to be alittle notchy i would of thought that its like a brand new gearbox as in perfectly smooth gear changes like a brand new car, I dont know input shaft?? is that the main shaft? if so i put an r33 gtr one in there they are alittle stronger.
A correctly built OS box should be nice and smooth...
Yeah they are rated at 1200hp with a 9k rpm shift limmitation- OS recomends 800hp
The input shaft is the splined shaft sticking out of the front of the gearbox. It transfers the rotational torque from the motor/clutch to the main shaft in the gearbox. These are a "weak" link for high hp GTR's. Unless your planning to run 400rwkw or more- it's not needed.
The OS gearsets are designed for the later r33 GTR box.
J.
J.
Are input shaft and main shaft the same thing? i think it did come with the input....... Well i know that when i snapped 3rd on my stock box he said something wedged itself between the main shaft and put smal hairline cracks in it, he said to me that this shaft doesnt have force on it so it doesnt ever brake he said he had one from an r33 so he used it. The only reason i broke it is because of the gear braking and wedging itself in it.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
